Old 02-12-2003, 05:48 PM
1511 1511 is offline
Default Meter and Tempo Change Markers
I've been battling this one today. For some reason, after setting a meter change marker and clicking the"apply" button, the dialog would go away... not. It would end up hidden behind the edit window.
As I made more changes, the original marker seemed to keep recording and applying them. Eventually, the meter ruler was showing hundreds of bar numbers after my tune was over. Eventually the ruler turned to hieroglyphics, then the beats and bars ruler went blank. G4 froze a couple of times before I was able to discover the hidden dialog box and theorize what might have been happening.
So, I started from scratch and would make sure to dismiss the dialog every time I found it hidden behind the edit window. Everything seemed fine after that, but a lot of time went down the tubes.
I'd sure appreciate if anyone could help me understand what I've been trying to piece together.
Thanks for any help,
Chas
Old 02-13-2003, 04:01 AM
Chompers Chompers is offline
Default Re: Meter and Tempo Change Markers
Trash you PT and DAE preferences.
How do I change the tempo and not have it move markers? aasteveo Tips & Tricks 4 10-16-2019 01:20 PM
help! insert the tempo/meter change in the session iamjungle Pro Tools TDM Systems (Mac) 13 04-26-2010 10:20 AM
Markers the same when I change Meter??? kfoody Pro Tools M-Powered (Win) 0 07-29-2008 11:00 PM
Preserving Markers/Tempo/Meter Settings ratava 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-31-2007 01:53 PM
How do you link and shuffle all tempo & meter change markers 1511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2003 12:22 AM
