Old 03-06-2024, 05:51 AM
pbthias pbthias is offline
Default Are tracks in closed folders suppose to ignore their record group?
Hi!
Just stumbled about this in a session:
(Pro Tools 2023.12.1, MB Pro M1, Ventura)
I have a live studio recording, all tracks are in a "rec group" so that when I hit record on one track, all the other tracks are going into record mode, too.
Now three of them are in a routing folder.
If I close the folder and enable record on a track, all tracks go into record EXCEPT the ones in the routing folder.
Those will only follow if the folder is expanded so the tracks are visible.
Is this suppose to work like this?
Old 03-06-2024, 07:33 AM
smurfyou smurfyou is online now
Default Re: Are tracks in closed folders suppose to ignore their record group?
Sounds like a bug. I always have my folders open so I can see recording in progress.
~Will
Old 03-07-2024, 12:58 AM
Could maybe someone try to replicate this?
Old 03-11-2024, 08:13 AM
Finally got around to trying this.
I'm seeing the same behavior whether a Routing folder or Basic folder. Will not arm the tracks if they're not shown.
Even more alarming is they get taken OUT of Record if you close the folder after arming.
This must be planned behavior, as the manual notes:
"The following are restricted on closed Folder tracks:
• Select/Split Notes (Event Operations)
• Step Input (Event Operations)
• Record Enable
• Input Monitor
• Special edit commands for plug-in automation
• Real-TimeProperties
• ElasticProperties"
This follows the same logic as Hidden Tracks. They won't arm and shown tracks will disarm when they're hidden.
I'm not sure I agree with it for folder tracks but as it is the GUI doesn't have any indication for a folder's REC status...
~Will
Old 03-11-2024, 08:24 AM
K Roche's Avatar
K Roche K Roche is online now
• Record Enable
• Input Monitor
I would think it is indeed a planned behavior because having visually hidden tracks automatically record arm, is inherently a potentially problematic situation
And If you know you are going to want to record tracks that are in folders from the start , one can alway simply save the session or template with those folders open (that is how I have my Templates saved)
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
NEW BUG - Session Import Clips Going Out Of Sync When In Closed Folders lukemcgregorphillips Pro Tools 1 04-03-2023 09:22 AM
Is there a way to spill such that nested folders will always initially be closed? workingduc Avid S1, S3, Dock and Control App 4 03-25-2022 11:21 AM
record enabling a group of tracks lululu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-05-2009 08:40 AM
How to put tracks in a group into record? ndaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-02-2006 09:19 AM
How do I arm a group of tracks to record? ProTooler Pro Tools TDM Systems (Mac) 2 04-13-2003 01:02 PM
