Old 01-01-2024, 07:44 AM
ritelec ritelec is offline
Default Manual install over Pro tools central install.
Hi.
It looks like I have issues with pro tools routing sends and receives.
When I downloaded the trial last week I did it through pro tools installing app.
Can I go into my account and down load it again manually and override the original app install ?
Thank you.
Old 01-01-2024, 08:48 AM
TJ Allen TJ Allen is offline
Default Re: Manual install over Pro tools central install.
I think it is extremely unlikely there is anything wrong with the install - this is much more likely user error/misunderstanding.
I’ve replied to your other post with a possible solution.
Old 01-01-2024, 08:53 AM
No where near enough info to get proper help. Describe the COMPLETE system and how you installed Pro Tools. Computer specs? What interface? Have you designated the interface to be the "audio engine" in Pro Tools(Setup Menu>Hardware). If you are on Windows, set Windows Sound Properties to use the on-board sound card and NOT your interface. I'm with TJ and suspect a re-install is not going to fix it. If you brand new to all this, that's okay. Just know that there is a lot to learn
Old 01-01-2024, 09:46 AM
The “central app” hopefully you mean Avid Link, the name should be right there in front of you.
Looking at your other thread about problems there is no sign of any issue with the software, neither is there likely to be. You are just a bit lost using Pro Tools.
Avid Link can be buggy at times, say not offering to install correct add on plugins, and many of us just uninstall it. But it will not cause the basic Pro Tools app to mis-install. Ultimately all it does is run the same installer as you would download from your Avid.com account.
Old 01-01-2024, 10:00 AM
Thank you all. Will Leave well enough alone and open up tutorials first.
Old 01-01-2024, 10:03 AM
jeam25's Avatar
jeam25 jeam25 is offline
Originally Posted by ritelec View Post
Hi.
Thank you.
Mc tumr8nk
2 n. Z . O
Sent from my SM-G991U using Tapatalk
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 01-01-2024, 10:04 AM
jeam25's Avatar
Originally Posted by jeam25 View Post
Mc tumr8nk
2 n. Z . O
R
Protools Ultimate
Yes, When I opened up my original purchases back in 2008, the salesman mentioned that when things aren't working it's probably me.
Thank you again all.
Old 01-01-2024, 11:07 AM
No problem at all. Just didn’t want you wasting your time reinstalling anything!
Old 01-01-2024, 02:16 PM
K Roche's Avatar
K Roche K Roche is online now
For future reference IMO best to install manually from your account "My Products" page As mentioned Avid Link can work fine but it can also be buggy at times
Also Besides some good basic tutorials
And once you get basic work flow down , IMO I prefer to custom name every thing and color code , especially Inputs-Outputs-Busses and Sends I think it is less confusing than just numbers to know exactly what is going where
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Can't install Pro Tools LE - Insert disc but no option to install Paul McConnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2010 08:13 AM
Why install Pro-Tools to install drivers for Mbox2 bigbobbysd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2010 07:42 AM
