Old 11-10-2023, 08:09 AM
cpjacobs cpjacobs is offline
Default Meter peak level after bounce?
I recently upgraded to version 2023.6 after coming from 2020. When I used to bounce audio, the meters would do a quick jump at the end of the bounce, registering the sample peak of the audio. I would use this as a quick indication to see where things landed. I'm not sure if that was a bug, but I certainly used it as a feature. The 2023 version doesn't appear to do this, and I'm wondering if there's a setting I'm missing that will restore this.
Much of the work I do is archival and doesn't use much processing, so I don't want to put a limiter on anything.
Thanks for any suggestions!
Old 11-10-2023, 12:00 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Meter peak level after bounce?
Hi maybe the peak/clip hold metering settings in Protools ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 11-14-2023, 12:04 PM
Thanks for the suggestion. There was no change after adjusting those settings. I was hopeful that the new installation didn't have peak hold activated and that that was the difference. I tried different meters and combinations of peak hold settings and nothing did it.
Mono channel meter level lower than Master’s meter level Armando Pro Tools TDM Systems (Mac) 3 07-07-2019 04:51 PM
Audio Suite Gain Plugin doesn't agree with Peak level in Track Meter blackbird99 Pro Tools 9 1 11-13-2014 10:14 AM
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
7.3.1 Send level meter just mirrors track level bashville Pro Tools TDM Systems (Mac) 11 01-16-2007 08:19 PM
channel level mirrored in send level meter daveh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2001 01:32 AM
