Old 10-27-2023, 06:32 PM
groovebrother groovebrother is offline
Default PT 2021.12 does not save every minute when asked to
Hello i was wondering if some of you have experienced this ?
i am and i think this is a problem.
Any help would be like paradise.
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 10-27-2023, 08:06 PM
audiolex1 audiolex1 is offline
Default Re: PT 2021.12 does not save every minute when asked to
I'm on 10.14.6 and 2023.6 is working like a dream. Just rename your current version with the number, install 2023.6 and rename that as well.
Now you have both versions to use.
Test out 2023.6 and go back to 2021.x for things if you need.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 10-27-2023, 08:48 PM
cwsand's Avatar
cwsand cwsand is offline
How often is it saving? What type of work are you doing? Mixing/Editing or recording??
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-27-2023, 09:15 PM
hey thx for the reply,
it's supposed to create backup file on every minute and actually i'm doing lost of mixing indeed.
But audiolex said it's working with him so now the mystery is expanding.
My update plan ran out before vs 2023 & can only download till 2022.5
My soundcloud page
Old 10-28-2023, 03:50 AM
midnightrambler midnightrambler is offline
Backups don’t occur when track is playing. So if you play a track that’s 3 minutes long without stopping, the next backup won’t occur until you stop the tape.
(Tape? Grandad!)
Old 10-28-2023, 06:39 AM
its2loud its2loud is offline
This.
Save early and often.
Old 10-28-2023, 07:48 AM
When this has come up in the past I wrote and shared a little monitor utility that reports on auto saves. I noticed recently it has some problems but if folks want this to play with I'll get it fixed.
Old 11-19-2023, 11:22 AM
personnally and if i may ... i'd just love to keep on saving on each minute what ever i do.
I don't mind trashing manually unwanted backups.
At the time if nothing was done in pro tools it would stop saving.
But as long as an EQ parameter would be changed, then pro tools would start saving again ...
I also regret the time of MDW3 where the undo was counted in pro tools and possible
My soundcloud page
Old 11-19-2023, 11:25 AM
Originally Posted by its2loud View Post
This.
i am sorry but i don't understand
My soundcloud page
Old 11-19-2023, 11:48 AM
What is complex here? Pro Tools won't autosave if its busy doing stuff, it *can't*... you want it to crash when trying to save while running? And it won't save unless there is some change to save. So what it does do is between those limits. And no you can't expect this to be significantly changed.
I just installed Pro Tools 2021.12 and show 2021.6...why? Zak7 Pro Tools 4 01-14-2022 09:11 AM
Can't save UI Customizations or Presets in 2021.6 Jess Davy Pro Tools 33 07-03-2021 03:46 AM
One minute I have space, the next minute I don't newtonab Pro Tools M-Powered (Win) 3 01-03-2009 05:38 PM
Why Is a 4 Minute song Bouncing as a 6 Minute Song rockwithrespect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-31-2004 02:37 PM
