Old 04-27-2020, 12:10 PM
SoundByLaura SoundByLaura is offline
Default Re: Ozone 5 crashing PT 2019.5
I've found a few workarounds for this issue and am going to post them here in case anyone else needs it.
This is working on PT 2019.12 on OS 10.13.6 High Sierra.
Workaround #1:
  1. Watch this video: https://www.youtube.com/watch?v=wrkkx67-KBY&t=8s
  2. Buy SoundRadix 32 Lives and DDMF Metaplugin2 to open and use Ozone 5 in a Pro Tools session.
Workaround #2 (for sessions that already have Ozone 5 on tracks)(this is the simplest workaround):
Make sure your Ozone 5 instance is active. Don't click on the plugin.
Instantiate or click on any other plugin and leave the interface window open.
Click on an Ozone 5 and the first plugin window will be replaced by the Ozone 5 window and you can use it.
Similarly, you can make an instance of Ozone 5 inactive, click on the plugin to open the window (it will say "Plugin Inactive"), then make it active and it will open the interface and work.
Workaround #3:
You can't instantiate Ozone 5 onto a track. But you can use Import Session Data to import a track from another session that has Ozone 5 on it, drag-to-move or option-drag-to-copy Ozone 5 onto whatever tracks you like, then use the method above to access the Ozone 5 plugin window.
You might consider creating a session that has a track/tracks with Ozone 5 on it and set that aside as sort of a template for using with Import Session Data. Or, import a track with an inactive O5 into your existing template(s).
Now I can work on old projects if necessary, and I can access Ozone 5 long enough to try to replicate some of my presets in Ozone 8.
(Yes I know I can open Ozone 5 presets in Ozone 8 but it doesn't always sound the same. Now I can work on that.)
iMac 27"; 4.0Ghz Intel Core i7; 16GB RAM; Pro Tools 2019.12
Old 01-30-2021, 11:57 PM
b mcgibney b mcgibney is offline
The video is no longer working but there are some great workarounds there. Thanks B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
iZotope Ozone 8 and Neutron 2 Crashing Pro Tools. TOM@METRO AAX Plug-ins 14 03-31-2019 01:50 PM
Update for Ozone 5 and Ozone 5 Advanced gives Pro Tools 10 1 11-27-2011 08:02 PM
Izotope Ozone 3 crashing Pro Tools 7 pcombs Pro Tools TDM Systems (Mac) 3 01-15-2006 06:47 PM
