This is a doozy for any Midi expert.
Just finished attaching a Korg X3 to the 001 and installed PT LE onto a new G4. Following the steps to setup OMS, the initial detection found the 001 and came back with a ? for the Korg X3. Continued to configure it manually, no problems thus far. Tried using the OMS test but did not hear anything from the X3 or from the 001 and none of the arrows flashed as the manual indicated either.
Moving onto PT I tried adding a midi track, selecting the midi device, selected channel 1 and record enable, still did not receive any midi data. Adding 2 mono aux tracks works fine, but still no midi data. Tried adding the 001 MIDI Driver to the OMS Preferences folder, still no luck. ……i’m stumped |
I need a MIDI file expert..... | planetkyle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-07-2008 04:38 PM |
Mixdown - Midi To Audio......need expert advice! | ScottFB | MIDI | 2 | 09-24-2005 06:18 PM |
Need sync, midi expert | ouguitarman | MIDI | 0 | 03-12-2004 08:57 PM |
Need Sync, midi expert help | ouguitarman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-12-2004 08:51 PM |
Need expert mac buying advice from an expert | superdood | Pro Tools TDM Systems (Mac) | 0 | 11-19-2002 06:14 PM |
