Old 10-23-2013, 11:27 AM
J-Xile J-Xile is offline
Default PT10 License Expired? (PT 11 Upgrade from 9)
I just got the Pro Tools 11 upgrade from 9, installed 10.3.7 and 11.2 and activated my licenses on ilok and everything was running perfect, not so much as a crash. Then I tried to bounce my session to MP3 sharing with Soundcloud and I get this window:
"Your license to use Pro Tools 10 has expired. Click the "Renew" button to register for a new license period."
I click renew and get this:
"This version of Pro Tools 10 requires authorization to run, but the authorization cannot be found on the installed iLok (serial number #x########).
If you have a license card for this product and with to use it to authorize this iLock. check the "Use license card" check box and the "Next" button. Uncheck the box if you with to authorize your ilok using an alternate method."
If I uncheck the box and press next I get a challenge and response, I have no idea where I am supposed to get the response code from. So I press "Back" to try another way.
If I check the box and press next I get this:
"Your iLok with serial number #x######## has a pending authoization for this software. Most likely this means that there is an outstanding challenge in the devixce for which the response has not been entered.
While the pending authorization exists, you may not transfer authorization from the license card to your ilok. Press "Next" to delete the pending authorization or "Cancel" to stop this operation."
I press next and get this again:
Now if I keep the box checked I get this again:
Ugh, an endless loop. I cannot figure out where to enter the challenge to get a response, and why I even have to do this if I have active licenses for Pro Tools 10/11 on my ilok 2 and they open fine. WTH?
Check out my music: J-Xile.com | Gear List
Old 10-23-2013, 11:46 AM
Default Re: PT10 Lisence Expired? (PT 11 Upgrade from 9)
Guess I fixed it somehow, I noticed I still had a Pro Tools 10 demo license on my ilok, deleted it and seems ok now. Bouncing to MP3/Soundcloud as I type.
License expired? natives Pro Tools M-Powered (Mac) 4 03-28-2017 05:27 PM
WTB: PT10 Upgrade License for iLOK waldo5150 Buy & Sell 5 11-05-2012 07:33 AM
wtb: PT10 Upgrade iLOK License waldo5150 Buy & Sell 0 10-27-2012 08:02 AM
Structure Expired Before License Date markpysher Virtual Instruments 0 06-04-2007 04:46 PM
G4 to MacBook, now iLock license expired? Logic Pro Pro Tools M-Powered (Mac) 6 11-14-2006 10:41 PM
