PT 11.02 CRASH ON SESSION OPEN (previous PT 11 sessions)
PT 11 crashing as it opens a session (which it had opened before).
Opens a window that says "Pro Tools has crashed - would you like to send report to Avid" (which I have done, but which does nothing). Don't know why I did to cause PT 11 to suddenly crash on opening existing sessions that opened a day before. Am attaching SANDRA report. I'm kinda baffled. Only thing I can think of that I did the day before was update iLok Manager, download an nVIDIA graphic update (via Windows Update) and updated iTunes (which I have since removed entirely). I have trahsed my preferences via TRASHER 11. Attached is a crash log that PT 11 kept. SiSoftware Sandra ID Host Name : Rex-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS SABERTOOTH X79 Serial Number : 1208011******** BIOS : AMI (OEM) 3009 10/05/2012 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz (6C 12T 3.8GHz, 3.8GHz IMC, 6x 256kB L2, 12MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : ASUS Core DMI2 (Sandy Bridge-E) 100MHz Memory Controller : ASUS Core (Sandy Bridge-E) Integrated Memory Controller Registers 100MHz, 4x 8GB DIMM DDR3 1.33GHz 256-bit Memory Module(s) Memory Module : G.Skill F3-14900CL10-8GBZL 8GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-14900CL10-8GBZL 8GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-14900CL10-8GBZL 8GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-14900CL10-8GBZL 8GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Hewlett Packard HP LA2405x (1920x1200, 24.0") Video Adapter : NVIDIA GeForce GT 520 (48 SM5.0 1.62GHz, 1GB 1.2GHz 64-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GT 520 (48SP 1C 1.62GHz, 1GB 1.2GHz 64-bit) Compute Shader Processor : NVIDIA GeForce GT 520 (48SP 1.62GHz, 1GB 1.2GHz 64-bit) CUDA GP Processor : NVIDIA GeForce GT 520 (48SP 1C 1.62GHz, 1GB 1.2GHz 64-bit) Storage Devices Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) : 119GB (C:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (E:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (F:) Seagate ST3000DM001-1CH166 (3TB, USB/SATA600, 3.5", 7200rpm) : 3TB (G:) WIBU - CodeMeter-Stick (41.2MB, USB1) : 39MB (I:) ASUS DRW-24B1ST c (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 119GB (NTFS) @ Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) Samples (E:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) Audio (F:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) Seagate BP (G:) : 3TB (NTFS) @ Seagate ST3000DM001-1CH166 (3TB, USB/SATA600, 3.5", 7200rpm) CODEMETER (I:) : 39MB (FAT32) @ WIBU - CodeMeter-Stick (41.2MB, USB1) Optical Drive (D:) : N/A @ ASUS DRW-24B1ST c (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS Patsburg LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASUS Patsburg High Definition Audio Controller Audio Device : Gigabyte HDMI Audio stub Serial Port(s) : 1 Disk Controller : ASUS Patsburg 6 Port SATA AHCI Controller Disk Controller : ASUS Asmedia 106x SATA Controller Disk Controller : ASUS 88SE9128 PCIe SATA 6 Gb/s RAID controller with HyperDuo USB Controller 1 : ASUS Patsburg USB2 Enhanced Host Controller #2 USB Controller 2 : ASUS Patsburg USB2 Enhanced Host Controller #1 USB Controller 3 : ASUS ASMedia XHCI Controller USB Controller 4 : ASUS ASMedia XHCI Controller USB Controller 5 : ASUS ASMedia XHCI Controller FireWire/1394 Controller 1 : Avlab Technology XIO2213A PCI Express to 1394b OHCI with 3-Port PHY FireWire/1394 Controller 2 : ASUS VT6315 Series Firewire Controller SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB-E XMB Ch 1 SMBus Printers and Faxes Printer : HP Officejet 6500 E709n Series (1200x1200, Colour) Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Re: PT 11.02 CRASH ON SESSION OPEN (previous PT 11 sessions)
Can you launch the session by disabling the plugins on launch?
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Will try - hadn't considered it. Just tried - and the session opened. Instantiated first plug-in; Channel Strip - no problem. Instantiated RVox (Waves) and it crashed). Hmmm. That's all I've got to work on so far.
Gonna try again opening with no plug-ins. |
Found the problem.
In doing some hard-drive cleaning the other day after switching entirely to PT 11 (and removing PT 10 from my drive); I seemed to have tweaked WAVES plugins. I could open each session with plugins inactive, then reactivate any plugin but WAVES without crashing. I suspected I might have effed up my Waves install, so I uninstalled Waves, and then fresh installed v9r13 and the Waves-AAX wrapper, and every session opened up without difficulty or crash. Got a little too deep into the corners with my dusting rag, evidently. |
It's best to always image your system drive before making ANY changes to it. Your nerves will thank you.
Can't open session - PT crash | Nystromfredde | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-06-2010 09:25 AM |
PT8 Crash on Open with Altiverb 6.3.1 in Sessions | holden | Pro Tools TDM Systems (Mac) | 4 | 05-09-2009 01:00 PM |
Unable to open previous sessions | john58b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2007 06:41 PM |
CAN'T OPEN SESSION DUE TO WINDOWS ERROR. CRASH. | smc108 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-09-2007 12:02 PM |
Previous Sessions Won't Open! | Peta Gabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2007 04:21 PM |
