Old 03-14-2013, 04:35 PM
rcd rcd is offline
Default Just bought an HD Omni. Does Avid offer free support to get me up and running?
Hi, I successfully chained my brand new HD Omni with my Digi 192 and but can't figure out how to find out how much latency I'm getting between the two unit's i/o's and then how to fix that. Also I have some setup questions as well.
Does Avid offer free Tech Support with newly purchased products - if so who do I contact?
Thanks!
Rich
Old 03-14-2013, 05:58 PM
KMcK KMcK is offline
Default Re: Just bought an HD Omni. Does Avid offer free support to get me up and running?
When you register your Omni you should get a couple of emails in return, and one of them will be a complementary support code that is good for (I think) 90 days, so you'd be able to contact them using that.
http://www.imdb.com/name/nm2384808/
Old 03-14-2013, 07:52 PM
nst7 nst7 is offline
You could also post your questions here. Us fellow owners could probably help you with most of it.
Old 05-08-2017, 06:42 AM
MSB Mastering MSB Mastering is offline
I too am trying to set up my Omni with a 192 on PT HD 10.
My first question is whether I can connect the Omni to the expansion port of the 192 as this only requires one digi-digi mini cable rather than 2.
Secondly, if it's possible, is there any way someone could make the .pio file available? Anything that works would be amazing.
Thanks.
Old 05-08-2017, 07:11 AM
JFreak's Avatar
JFreak JFreak is offline
Yes you can. The limitation regarding Omni is (I think) that you can only have one. But if you connect 192 as first interface, you can daisy-chain another. Maximum is two interfaces, because the DigiLink cable can only carry 32 i/o
Janne
Old 05-08-2017, 07:13 AM
JFreak's Avatar
You don't need to worry about that as PT software handles delay compensation when you use DigiDesign/Avid branded interfaces
Janne
Old 05-08-2017, 11:37 AM
Thanks. I'm actually in a rush to set that up for a recording next week. Please contact me offline and I'll pay for someone to help me get this up and running. Fortunately, I'm not too hard to find... Thanks.
Old 05-08-2017, 03:58 PM
jjnssn jjnssn is offline
Native or HDX, it is fairly straight forward. Not sure why you wouldnt use the Omni as the monitor and hang the 192 as the secondary.
Do you have a separate clock or will you run loop sync? The hardware manual is straight forward. The pio file is generated by pro tools.
How much longer will Avid offer the free Pro Tools 10 update from PT9? risemymuffins Pro Tools 10 3 03-08-2013 06:54 PM
free TAB offer cary chilton Eleven Rack 6 10-08-2012 06:15 AM
Free Avid Eleven, Strike, Velvet Plugin Bundle Offer With Pro Tools Purchase??? skiman123 Pro Tools 10 0 02-11-2012 02:13 PM
Dear Avid customer support! Would you please answer my both avid support cases Ale Pro Tools HDX & HD Native Systems (Mac) 0 11-24-2011 01:56 PM
Question for Avid Tech Support: Omni Calibration Jack Ruston UK Pro Tools TDM Systems (Mac) 5 10-07-2011 08:08 AM
