Old 04-05-2011, 08:50 PM
basslik's Avatar
basslik basslik is offline
Default stability over prior to PT9
Good day everyone,
I just wanted to get a general consensus from past experiences if I may.
Since PT9 is still kind of early in the game for most who haven't acquired PT9, so from the past OS systems, and earlier versions of PT which can everyone agree that was the most stable? CHEERS
Myself I found Tiger & 7.3 the most stable.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 04-05-2011, 09:56 PM
Dism Dism is offline
Default Re: stability over prior to PT9
7.4.2 was a great release in terms of stability back on Leopard. But 9.0 beats all versions I've worked with so far.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 04-06-2011, 01:33 AM
All versions worked for me by keeping the system clean and following the guidelines provided in the sticky threads. At least I would consider it stable (not necessarily bug free).
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 04-06-2011, 06:44 AM
basslik's Avatar
Great folks, keep it coming. I never had the opportunity to use 7.4.
Old 04-06-2011, 06:52 AM
OS9 PT5.1.3
Had plenty of bugs but very stable in terms of crashing.
Old 04-06-2011, 09:01 PM
basslik's Avatar
Originally Posted by Frank Kruse View Post
OS9 PT5.1.3
WOW, I wish I was fortunate enough to use PT in the beginning, man I bet all you folks fly on PT.
Old 04-07-2011, 12:23 AM
tamasdragon tamasdragon is offline
From version 5 up to 9, I find 9 to be the most stable one. On multiple machines.
my blog:Tamas Dragon
Old 04-07-2011, 06:44 AM
basslik's Avatar
Kwel tamasdragon. Whick version of 9?, also what about the issue with the grid lines in 9.2 ?
Old 04-07-2011, 06:50 AM
sunburst79 sunburst79 is offline
So far 9 has been pretty good fo me. I'm still on 9.0 and haven't upgraded to 9.0.2
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-07-2011, 07:03 AM
Chris Watkins Chris Watkins is offline
Properly done my MIX on xp runs as good as OS9 v5 does/did.
But, so much of that was in the OS config, since OS9 was stable PT was.
But yeah, osx 10.6 is getting to where I haven't rebooted in
over a month and that's right in line with the other systems,
only since it's actually stable unix running the show, I'm
sure unless for update or install required I could do into the 100's of days, etc.
And, as long as your mixing hybrid, v5 and v6 are not as dated as one might think.
[IMG] code is Off
Uninstall prior to crossgrade? ldeadhead Pro Tools 9 5 02-23-2011 04:26 PM
How to insert Compressor prior to ProjectMix I/O JRodJr Pro Tools M-Powered (Mac) 4 07-18-2006 07:37 AM
Return to prior Selection carmichael Tips & Tricks 3 09-23-2005 07:25 AM
Can't hear myself prior to the punch JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2002 06:30 AM
zipping files prior to backup MrMike Tips & Tricks 3 09-23-2001 11:22 PM
