Old 02-23-2011, 02:27 PM
ldeadhead ldeadhead is offline
Default Uninstall prior to crossgrade?
DUC search seems not to provide me with a definitive answer so ...
I have PT8(.03)LE with a 003 desk. I have purchased a crossgrade PT9. Will I have to / or should I uninstall PT8LE prior to (or during) the installing of PT9?
I have the required iLok key that I previously needed for the supplementary programs that came with my PT8LE although if memory serves me right I don't actually need the iLok present in the system for PT8LE to work (away from studio for a day or so but want to install PT9 at end of the week on my return).
What of the included software i.e. Guitar Rig LE
Thanks in advance
Old 02-23-2011, 02:49 PM
slater05 slater05 is offline
Default Re: Uninstall prior to crossgrade?
Uninstall 8 BEFORE installing 9
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 02-23-2011, 03:11 PM
thanks for the speedy reply.
dare I ask why or how you come to know this? is it documented anywhere?
Old 02-23-2011, 03:20 PM
Obsidian Dragon Obsidian Dragon is online now
The general rule of thumb is to do a clean install whenever possible. It is the perfect time to clean out the files. Some folks go so far as to reinstall the OS from scratch (or at least a from a backup image). I was too impatient and did the updater on one of my systems and everything worked fine. So the absolute answer is "no" you don't have to uninstall PT8 to install PT9. The best answer however, is "yes" it is recommended to uninstall PT8 and do a full install of PT9.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 02-23-2011, 03:33 PM
I know it makes sense
Just tempted to leave PT8LE on (and possibly working) in case of any problems say with updated 003 drivers.
sounds like it's time to acronis true image the system and start over - joy!
Old 02-23-2011, 04:26 PM
Absolutely use Acronis!! When it comes to the question of uninstalling, most installers will tell you when you try to run them. I would backup your drive and then run the 9 installer and see what it tells you(out of sheer morbid curiousity)
[IMG] code is Off
upgrade/crossgrade- uninstall first ? bonzerboy Pro Tools 10 7 10-21-2011 11:50 PM
stability over prior to PT9 basslik Pro Tools 9 17 04-09-2011 09:00 AM
Will PT9 crossgrade uninstall PT8? gtomassetti Pro Tools 9 2 11-10-2010 04:51 PM
Return to prior Selection carmichael Tips & Tricks 3 09-23-2005 07:25 AM
Can't hear myself prior to the punch JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2002 06:30 AM
