The audio device buffer underflowed.
When simply trying to play the demo session (The Legion), I get the dreaded -6085 error, with this message: The audio device buffer underflowed. If this occurs frequently, try decreasing the "H/W Buffer Size" in the Playback Engine panel or remove other devices from the audio firewire bus.
This system doesn't have a firewire bus. I'm using a USB MBox 2 Mini and MOTU micro lite. Aside from the iLok, I've tried it with all other USB devices unplugged or turned off. I've tried decreasing the HW buffer size, as the dialog suggests, which doesn't help, but does cause audio clipping, and eventually, the same dialog. I tried turning off the wireless network adapter, but that didn't help. I have the session loaded on my D drive (a 2nd internal hard drive). Also tried loading the session on an external USB hard drive, which also didn't help. The only option I can think to try is to put the session data on an external sata drive, but I don't have one to test that with. Would it help? What else should I look at? Running on a new PT9 dedicated HP dv7 with Intel i7 processor @ 1.6 gHz, 6 GB memory, two hard drives, 64 bit Windows 7, Mbox 2 Mini audio. |
Re: The audio device buffer underflowed.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Audio Device Buffer Underflowed | advision205 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-10-2011 09:52 AM |
PTs 7.3.1, 002, Mac G4."Audio Device buffer underflowed..." | Gallo Wood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-17-2008 04:30 PM |
"The audio device buffer underflowed............. | johnforkelid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-23-2007 10:35 AM |
The audio device buffer underflowed | rhendee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-30-2007 08:59 PM |
audio device buffer underflowed?? HELP! | chagos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-10-2005 12:14 AM |
