HD OMNI How many channels of conversion ?
After reading the manual and data sheets for the Omni.
Am I correct in assuming that the HD OMNI I/O actually has four simultaneous channels of A/D conversion and 8 channels of D/A ??? Perhaps and Avid rep person could clarify ? Thanks , Kevin
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Re: HD OMNI How many channels of conversion ?
2 mic pre inputs 4 line inputs 8 line outputs 8x adat inputs and outputs 16x AES inputs and outputs 2x spdif inputs and outputs Chris
It's 8 channels of D/A, but it's only 4 channels of A/D.
So you can't run the 2 mic pre's and 4 line inputs at the same time? Chris
The HD OMNI is an 8in/8out interface, so you can do most any combination of 8 in and 8 out using any of the following (in pairs): Input channel choices: 4 Analog channels (1 and 2 have pre-amps for Mic/DI/line - 3 and 4 are TRS line only) 2 Channels AES (XLR) 2 Channels S/PDIF (Coax RCA or Optical) 8 Channels of ADAT or S/MUX Output channel choices: 8 Analog Outputs (DB25) 8 AES Outputs (DB25) 2 Channels S/PDIF (Coax RCA or Optical) 8 Channels of ADAT or S/MUX * Additional TRS outputs that can mirror 1/2 or 7/8 * Headphone Output with optional separate headphone cue mix
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
Their online information is wrong then!! It clearly says 2x 8 channels of AES i/o (so total 16 channels i/o) Thats a bit confusing if it can only do 8 i/o max Chris
The OMNI itself has more than eight available inputs and outputs, but it's limited to 8x8 in Hardware Setup.
Omni is such an odd box......
The decision to NOT just have 8 in and 8 out analog plus the usual AES/SPDIF for two of the in channels (like 888, 192 etc...) is just weird to me. As a music guy this box is just underpowered enough so that I will always need some other box to get the other 4-6 inputs..... mic pres + converters (think recording trios, small groups)...... 8X8.... no problem.... with this box it is 2 mics in then 6 channels of outboard preamps, 6 channels of conversion to ADAT..... Of course there are no 6 ch converters so I will have 8 anyway..... after that I don't see any reason not to just get the 8X8X8 192ish box...... and simply use outboard pres...... Then again, I guess I am just not the target group for this. More analog outs than in...... interesting choice...... -Lee
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
It seems the Omni is aimed at those needing just a few inputs at a time, with just a little bit of expansion if you need it. One way I can think of would be to get the ISA 428 preamp with digital card, which would give you 4 pretty good preamps and pretty good conversion. Then you would have the 2 built in preamps and maybe a 2 channel preamp for the remaining analog ins.
The only issue with getting the 8 x 8 x 8 is you'd still need preamps/DI's, plus some kind of monitor controller. |
Yes that is what i thought the manual was saying because it said you could input only 4 analog channels into Pro tools but you could monitor up to 7.1 surround . Thanks kev
How to get 8 channels of XLR Preamps with Omni? | charlesHindigo | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-20-2013 07:09 AM |
HD OMNI: Meters: channels lights up the neighbor channel | ha2dorff | Pro Tools HDX & HD Native Systems (Mac) | 12 | 12-26-2012 03:22 AM |
5 month old Omni lost 50% output on channels 1 & 3 | ronwasserman | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-13-2012 03:44 AM |
HD Omni 24-bit/192kHz? Limits on channels? | 68topls | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-23-2012 07:14 PM |
HD OMNI multible recording of channels? | 24BitMusic | Pro Tools TDM Systems (Mac) | 2 | 01-01-2011 04:05 AM |
