Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 06-02-2009, 05:11 PM
rroselavy rroselavy is offline
Default DD Client: Email Address Cannot be Selected
Hello,
We've been using the DD Server and Client for a couple of years with great success. I just recently upgraded to Mac OS 10.5.7 onto a user's computer and we are having one minor problem with the DD client: The interface does not respond when we try to select email addresses from the Address Book. Reopening the Address Book pane sometimes makes it work, but later it will stop working again.
Is this a known issue and is there a fix?
Thanks very much,
-Scott
Old 06-05-2009, 11:53 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Default Re: DD Client: Email Address Cannot be Selected
me too. . I posted on here about that like 6 months ago. . no response.
Old 06-06-2009, 09:24 AM
Thanks for the reply.
Did your problem occur on a client machine that was upgraded to Mac OS 10.5x? or on a new install or different version of the OS?
I am wondering if the DD client is actually a Java App, and if the OS install modified the Java environment, causing some conflicts.
We tried trashing the DD client prefs, as well as do some fiddling with the Java Preferences. At first the problem seems to go away, but then come back again. We never had the problem BEFORE upgrading to 10.5.
Any clues you could give me might be helpful for troubleshooting.
Old 06-06-2009, 10:20 AM
Its happens on both of my machines that were fresh drives then fresh install of 10.5 then combo updated to 10.5.5 on one machine and 10.5.6 on another machine.
so the os was not upgraded. . it was fresh.
Email address change bderkach General Discussion 2 07-18-2013 10:03 PM
How do I change my email address?! [solved] EricWillhelm General Discussion 10 05-28-2013 06:20 PM
Changing email address Doc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2002 01:28 AM
DigiDesign, I need your email address to... John Palentin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-31-2000 10:14 PM
