Mix core and farm cards pci ?
What is the prefered pci voltage that will run these cards on a pc. My Tyan Tiger MPX dual processor motherboard has pci slots that are 5.0 volts. Will this work or does it have to be 3.3 volts?????Will it fry my cards if i place them on this motherboard?? I have a mac quicksilver 733mhz with 1.25gb of ram, but my tyan has 3 gigs of ram and is much faster. should i stay with mac or switch to the pc tyan board??????Thanks in advanced, TONY
Re: Mix core and farm cards pci ?
Anyone????
Try emailing tech support, or maybe download the manual (Tech Docs).
Also, note that 1.2Gb of ram is plenty to run a Mix system (was spec'ed for 512, with >=1gb recommended). Check the compatibility link above and make sure that your TYAN computer is compatible (chipsets, etc).
steve Your Heaven |
Does anyone know if the cards will work in a pci slot that is 5.0 volts??????Techsupport doesnt seem to want to answer my email....
I use a mac 733mhz quicksilver but i can only get it up to 16 tracks and then it starts bogging down and ive only used maybe 6 rtas plugs and it has 1.25 gigs of ram....i need to upgrade to a faster mac or if someone could please tell me if the cards will work in a pci slot that runs at 5.0 volts then i could use a much faster pc motherboard with 3 gigs of ram...
please does anyone know?
You wont have a problem with the voltage, they are made for both platforms...
However when we tried it one of the older mix cards wasn't compatable with winXP other than that it all worked great... Cheers N |
thank you so much for the answer. That is gonna be great.....I will try it tomorrow...
HELP! core,farm,dsp cards & lights? | A Spooner | Tips & Tricks | 3 | 11-11-2009 01:45 PM |
mix core and farm cards | maddogz | Tips & Tricks | 15 | 08-12-2009 09:01 AM |
Old Mix Core and Mix Farm Cards | guitarjerry | Pro Tools TDM Systems (Mac) | 7 | 02-17-2008 09:36 AM |
Mix core card and 2 DSP farm cards | Polosul | Pro Tools TDM Systems (Mac) | 3 | 06-19-2005 07:05 PM |
Farm & Core Cards????? | Flosstein | Pro Tools TDM Systems (Mac) | 7 | 01-17-2002 12:54 AM |
