Old 09-22-2005, 10:03 PM
carmichael carmichael is offline
Default Return to prior Selection
Is there a way to return (re-select) the prior selection (I believe some software uses the backspace key for this) -- I often lose my place after carefully making the perfect selection? I've dug through all the keyboard shortcuts and can't find this.
Thanks!
Old 09-23-2005, 03:22 AM
Default Re: Return to prior Selection
Thanks!
Yes the Waveframe did this. It´s one of the biggest downsides of the way PT handles edit selections. Because there are no dedicated edit in and out markers there is also no undo to "unselect". A very cumbersome work-around is that you punch in a selection only memory locator. But imagine keeping track of all those hundreds of selections you make when working...
Again one good thing digi didn´t learn from AudioVision..
Frank.
Old 09-23-2005, 06:58 AM
TLmix TLmix is offline
a few more workarounds.
1. you can separate the reigion that you have selected ( command E)
2. create a dummy midi track. Put it in "blocks". Make your selection in the MIDI track. Shift+Command+3 to consolidate selection. You can name it whatever you like as a marker.
TL
TL
Warner Bros. Studios
Old 09-23-2005, 07:25 AM
Thanks!
I'd be so lost without these forums and kind people like yourselves.
stability over prior to PT9 basslik Pro Tools 9 17 04-09-2011 09:00 AM
Uninstall prior to crossgrade? ldeadhead Pro Tools 9 5 02-23-2011 04:26 PM
what to listen to ?? soft return or in return ? martin coria Pro Tools M-Powered (Win) 0 10-13-2010 04:11 PM
Return/Enter key won't return to 0:00 on Pro Tools LE on Mac marcnyc Pro Tools M-Powered (Mac) 2 08-31-2007 02:29 PM
return to selection command? joelaw1971 Pro Tools TDM Systems (Mac) 1 03-03-2005 08:47 PM
