Old 04-10-2005, 02:25 PM
William 2014's Avatar
William 2014 William 2014 is offline
Default Assigning Midi channels to notes
As my midi knowledge is pretty primitive i'm gonna need some help here to see if what i'm thinking is gonna work.
Working with Kontakt now on PT LE 6.4 and have some sample CDs i'm using, like KIck Ass Brass by AMG.
I've set up several instruments , 7 trumpets, in Kontakt and what i would like to do is, assign a different midi channel (for example channel 2 ) to just one note within the track i'm programming in order to get this note to trigger another Kontakt instrument set to midi channel 2 (same trumpet with different layer/effect )
I already did that by drawing the note on another track and setting this track to midi channel two and it works but as there are many instruments in the instance of Kontakt the way i'm working now i'd have to open and work over the same amount of tracks as instruments i have in Kontakt.
It would be much simpler if i had the notes triggering different samples in just one track.
Could you tell me if there a way of doing this?
Or any other workaround you might think of ?
Thanx a lot for any advice on this
Will
iMac Intel Core 2 Duo 3.06 GHz / 8 GB RAM ; PT LE 8.04
Old 04-10-2005, 11:51 PM
Default Re: Assigning Midi channels to notes
Ok , now i know it can't be done, thanx for not insulting me
Old 04-11-2005, 06:39 AM
pk_hat pk_hat is offline
You have to assign new midi tracks for each midi channel playing a different sound.
www.myspace.com/krou
Old 04-11-2005, 03:03 PM
Thanx pk_hat altough i'd guessed it while thinkin' a little deeper on the matter , oh well, i already have 20 midi trax running and it keeps growin'
Assigning midi channels from structure essentials to axiom 49 djguitarboy23 Pro Tools M-Powered (Win) 0 01-18-2011 06:17 PM
assigning different instruments to different midi channels jsbrown MIDI 1 12-14-2008 01:19 PM
Assigning individual MIDI channels with Kontakt bousley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-26-2003 01:16 PM
Assigning Midi Channels skyhawk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2003 09:44 PM
Assigning MIDI tracks/channels KT Digidesign Hardware & Software 1 10-17-2001 06:49 AM
