Waves quietly removed RTAS with version 9.91...
Just went to update to 9.91 to test Smack Attack on a project, since it's part of my Mercury bundle.
Well, new Waves Central needed. No problem. Download and run. Unsupported OS. Looks like only 10.10.5 and later will even run the new installer—not just unsupported, removed. So, I made my way through the site and somehow stumbled upon the Legacy Installer for version 9.6 with an accompanying version of Waves Central ( which immediately updates itself and won't run and get the same error, by the way). -->Bottom line is the fine print listed under the Legacy 9.6 Installer. "Last version to support OS 10.8, 10.9, DAE" All DAE support (RTAS) has been removed. Worse, the new installer ( if you happen to be on Yosemite or later) updates the older versions to remove RTAS. They cannot coexist. A heads up would have been highly appreciated. That's a LOT of users unable to buy any of the latest plugins. Crazy there hasn't been any info posted. |
Re: Waves quietly removed RTAS with version 9.91...
Is this why after I updated I can only open the plugins in studio rack in PT 10?
Yes, it is. You have to uninstall, then use the offline 9.6 installer and you cannot use any plugins after 9.91 was released (just Smack Attack, so far).
So they will work in the studio rack this is what is intended ? And thing after 9.91? I don't see their instruments such as the synths ? I'm only seeing the main processing plugins .. what's the reason behind the studio rack only?
Thanks for the heads up |
I don't need the studio rack in PT10.3.1 or PT11.3.2.
I too went through what the op went through when I got C6 a couple of weeks back. Because I purchased through Waves themselves it was already entered into their system so all I had to do was to install it and move the license asset to my computer. I used the existing 'updated' WC to go online and move the license asset to my computer. I then disconnected from the 'net and used the offline installer to do the C6 install. So now I'm good to go. |
StudioRack doesn't support VIs. I don't fault Waves for dropping RTAS, but it sure would have been nice if the last version BEFORE THIS RELEASE said it would be the last version that would contain RTAS, 32-bit versions of Pro Tools support, and allow installation on Mountain Lion and Mavericks, though. Last edited by Matt Hepworth; 05-08-2017 at 03:51 PM. Reason: Clarity, spacing. |
They have an offline installer available.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
That's already been mentioned (legacy installer in post 1). What's also been (or should have been) mentioned is that offline installer will not ever be updated to include new plugins.
Now I don't know where all the tentacles for the Waveshell are or go to; what I'm wondering if it would work is to save a copy of the 9.6 version to a thumb drive or memory card and the 9.91 version to another drive/card and swap them in and out as necessary? Kind of a hassle but if it works |
Upgrade from 11 to 11.3.1 removed version 10 | Hamilton1 | Pro Tools 11 | 1 | 10-29-2016 10:12 AM |
Avid Quietly Launch A Pro Tools Plug-In Finder Page On Their Site | muesli | AAX Plug-ins | 15 | 01-26-2013 09:34 AM |
Tab to MIDI note removed in version 8 ? | poly915 | Pro Tools TDM Systems (Mac) | 5 | 10-07-2010 09:20 AM |
Any tips for recording guitar quietly? | Digital_Mind | General Discussion | 4 | 05-02-2006 06:59 PM |
which version of waves supports rtas? | J. FO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-15-2002 02:21 PM |
