Cannot install PTF
I truly hate to be this guy, but I cant even get PTF to install...
It appears like its trying to, but then nothing happens. I am using it with a Focusrite 6i6 using the USB cord supplied by Focusrite. Please see the attached pictures to see the trouble I'm having. After the last photo it just returns to the purple installation screen. Any advice would be HUGELY appreciated. Again I really apologize for this being my first post. |
Re: Cannot install PTF
No need to apologize. I'd help if I could. Many people seem to have trouble with PTF. It might have bugs.
Phone help from Avid is expensive. I found a downloadable book that's helped me. "Pro Tools First 12: How It Works" by Edgar Rothermich. He has detailed explanations about installation. I think it's still $15. Good luck with this.
late 2014 Mac mini7,1 2.6 GHz Intel Core i5 OS 10.12.6 (Sierra), 8 GB 1600 MHz DDR3 WD portable hard drive - 320 GB, formatted HFS & Journaled, plus turbo Exit, stage left |
The dialog in your 4th picture usually happens when windows can't interrupt the command that was used to launch that installer. This is usually more of an OS issue than something wrong with PT.
Is this system up-to-date with updates and patches? Have you had any problems installing any other software? Is there any antivirus, like Norton or some other running? You can try disabling antivirus during the install to see if it helps. PT is made up of a bunch of individual installers. My guess is that one of them is failing, causing the main installer to roll back, which leaves you with nothing. |
Install PTHD 8.1.1 udater on Win7x64 and says valid install not found 8.0.3 is there | rnygren | Pro Tools TDM Systems (Win) | 2 | 10-25-2014 10:58 PM |
Mountain Lion/PT Install/Ilok install problems | alex obradovic | macOS | 7 | 07-14-2013 06:19 PM |
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
Can't install Pro Tools 8! Clean install, new system, Vista! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 01-09-2011 11:16 AM |
Can't install Pro Tools LE - Insert disc but no option to install | Paul McConnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-22-2010 08:13 AM |
