Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 11-07-2015, 01:21 PM
NipL NipL is offline
Default FT Solo loosing contact and click timing issue?
Hi
#1. All seem to run fine starting up a session but trying to optimize a bit and closing hardware dialog - audio engine loose contact.
All meters are running, but no sound out - until I close and open session again.
I don't have to exit PTE, just session thingy is enough.
Is there a button somewhere to activate audio engine again without this procedure?
Many daws have a audio engine button lit that is turned off if stopped.
#2. Listening to a drum track to Xpand2 and activating click, click is late by far.
So I did a test and recorded out from click onto a new track and compared to grid and it's seriously late. Haven't checked in numbers, how many samples, but 10cm between quarternote grid it's about a one cm late.
I just did a simple template session from pop, and there is one drum track to xpand2. Nothing added at all as plugins or other stuff. But I should mention that I get two notifications starting a session about two delays somehow - I think I unchecked something regarding what plugins to use.
I tried to activate playback engine delay compensation to 1024, if that interfer with what is loaded in that pop template - but no different, click remains very late something is the range 20-30ms at least.
Anything I missed here?
Fast Track solo versions fw 1.02 and 1.04 as it states in hardware dialog.
10.3.4 for PTE. Default setting 256 I cannot change for Fasttrack.
Any tips welcome.
Thanks.
Did a screen dump - and it seems PT click tracks does not work properly - delays are compensated for twice or something - so click comes one asio buffer extra.
Clicktrack error dump
Reference is the grid at 2:1:0, and click either from imported(created in Cubase) ir PT clicktrack - and then rerecorded through a mike into a new track.
When installed it was really obvious, since latency was set to 512 samples.
Played drum tracks on the grid and click was off seriously.
midi timing erratic even with click on LE 7.3 Greg F 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 07-18-2009 03:50 PM
anyone ever had mysterious Click/timing issues? stephen duffy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-22-2006 06:57 AM
002 loosing contact crisis freddyb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-13-2006 12:18 AM
Loosing midi click+ 6.2.2 + 2X2 gig G5. Anyone? fab Pro Tools TDM Systems (Mac) 1 12-09-2003 08:07 PM
Loosing contact with Direct I/O mongokongo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-05-2002 02:26 AM
