Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 09-12-2013, 08:09 PM
Emcha_audio's Avatar
Default Re: Fast Track Pro out of order after last driver update
Ah okay, so you're just using it as a sound interface. Well that takes off a few things I was going to write
Manny.
Wave-T.com
Old 09-13-2013, 12:32 PM
oifhopif oifhopif is offline
Hey there,
I have the same problem here after the new software and firmware update.
I have win7 x64 and now using the older software 6.0.7. I had problems with the S/PDIF port, so I updated it.
After the update, my computer got slow and I had several times this bluescreens:
Even after I installed my whole system new i get this bluescreen...
Now I'm using the software 6.0.7 and have these noises and speed changes.
Is there really now way to downgrade the firmware??
Old 09-13-2013, 03:49 PM
kleewan kleewan is offline
I'm sure there is a way, almost every electronic device has some kind of "emergency procedure" to flash his firmware. For example, when you run out of power during a firmware update, or simply when the firmware itself gets corrupted for whatever reason.
Only people from Avid could help us. I live in Italy, I can't send my device in the US just to get its firmware downgraded, that's stupid. I can do it myself, I only need to know how.
Please help us!
Old 09-16-2013, 11:45 PM
avi-dan avi-dan is offline
I have same problem, windows restart after upgrading to 6.1.10 version.
The restarts only happened when using S/PDIF output.
I use windows 8 64bit.
did someone fine a solution for that?
Old 09-19-2013, 01:07 AM
Vincenzo87 Vincenzo87 is offline
I also have problems with the new firmware, the audio It clips when I use a base in the background and sound
Please update!
My Hardware: Intel i7 950, Motherboard Asus Sabertooth x58, Ram Corsair XMS3 6GB 1600Mhz, Hard Disk Samsung SSD 840 PRO, Windows 8 64bit, Video Card Nvidia GTX 560TI
  #16
Old 09-24-2013, 04:35 PM
frelser frelser is offline
Hello at Avid....
I have the same problem with my fast track pro...since i updated the firmware to 1.0.2 and the driver to 6.1.10 I've been experiencing too many death bluescreens and lacks of audio....this is becoming annoying and i demand a solution urgently to this issue...
fyi...i'm from Mexico and i have a dell laptop...windows 7 home premium 64 bits...intel core i5 2.5 Ghz....RAM 4 GB...the DAW i use is Ableton Live 9...
As the other guys said...there must be an option to downgrade the firmware...unless a new firmware updating is on its way because the 1.0.2 sucks...
please i need a solution ASAP...PLEASE!!!
thanks in advance...frelser...
  #17
Old 09-25-2013, 11:35 AM
Koss64 Koss64 is offline
I am int the same problem , i upgrade the firmware to 1.0.2 and I've got the problem as yours , but i think find a particular solution . I installed the 6.0.2 driver , and its disappeared the problem . / I only checked streaming , but i think , during recording etc. it have to work normally ! /
PS: Sorry for my english , I am hungarian .
  #18
Old 09-25-2013, 11:42 AM
Here is the driver 6.0.2 :
HTML Code:
http://avid.force.com/pkb/articles/en_US/Download/Fast-Track-Pro-Drivers
  #19
Old 09-28-2013, 07:25 AM
has someone already checked this? I Havn't so much time right now...
  #20
Old 09-29-2013, 02:07 PM
skykill3R skykill3R is offline
I have the exact same problem. Everything was working well before the upgrade but after it, I experience harsh sound and sound cut-offs. I am using Win8 64 bit.
Will someone from AVID please help us with the problem you created with the faulty upgrade?
Thanks.
win 8 installs own driver for Fast Track Pro clsbd_lou General Discussion 2 02-12-2014 06:49 AM
Driver problems with Fast Track Pro USB musictomyears FireWire & USB Audio Interfaces (Mac) 1 10-15-2013 12:16 PM
Fast Track Ultra 8R Driver Beto Chaves macOS 1 10-13-2013 02:53 AM
Problemo of new Fast Track 6.1.12 driver tkrojam FireWire & USB Audio Interfaces (Win) 2 07-20-2013 10:17 PM
