Program failed to initialize properly (0x80000003)
Since I couldn't bear with the downtime while putting an new disk into my laptop I got the "fantastic" idea to clone the disk with Norton Ghost.
Everything seemed to have worked proplerly until I try to start protools. Program failed to initialize properly (0x80000003) After some googling I found out that this is usually caused by garbage in the registry, that I needed to uninstall and reinstall do some fixes and what not. All that did not work. The problem was that Pace anti piracy does not handle cloning very well, everything ran smoothly after a reinstallation of the pace drivers. Decided to document this here on the forums since my search for this title didn't answer anything about my particular problem. Regards, Jón Hallur Dell Inspiron 9400 Win XP ProTools LE 8 |
Re: Program failed to initialize properly (0x80000003)
I make an image of my System Drive daily using Acronis True Image and have never had any problems with the PACE drivers. I also keep the PACE drivers current.
Cheers,
+1 for Acronis
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
HELP I'M IN DRIVER HELL! "The application failed to initialize properly (0xc0000005). | gerry c | Windows | 8 | 01-06-2014 08:22 AM |
Pro Tools 7.4 failed to initialize properly(Oxc0000142) | Kentjm | Pro Tools 10 | 2 | 07-13-2012 03:49 PM |
application failed to initialize properly (0xc000001d or 0xc0000142) | graveleye | Pro Tools M-Powered (Win) | 4 | 04-12-2011 05:58 PM |
THE APPLICATION FAILED TO INITIALIZE PROPERLY (Oxc0000005) | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-17-2009 05:01 AM |
PTLE 8.0 Failed to initialize 0x80000003 | RhysC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-17-2009 07:31 AM |
