Old 08-01-2010, 09:00 AM
Inthebox Inthebox is offline
Default URGENT: Installing 8.0.0 -> 8.0.4 on snow leopard
We have just installed Snow leopard 10.6.3 on our 2 x 2 Ghz Xeon intel mac.
We have tried to install PTLE 8.0.0 that came with the 003Rack with no succes. Error #-5000 to do with authorization prevents us from satrting PT up for the first time.
We now learned that 8.0.0 only runs on Leopard 10.5 and 10.4.x.
We are downloading the 8.0.4 update right now.
How do we go about installing PT 8.0.4 now??
We are starting courses tomorrow morning, so we need help right away.
Thanks
-Box
2 x 2 Ghz Dual Core Intel Xeon
8 GB 667 DDR2 FB-DIMM
Mac OS 10.6.3
DIGI 003 Rack
Old 08-01-2010, 11:39 AM
smfelton's Avatar
smfelton smfelton is offline
Default Re: URGENT: Installing 8.0.0 -> 8.0.4 on snow leopard
Did the installation fail or will it just not run ? If it installed ok just put the 8.04 on and you should be fine. If you have registered you should have a full installer for 8.03 which will run under Snow Leopard, but you should be fine, we have a machine on SL that was installed from 8.0 DVD then upgraded through CS releases then 8.03 now 8.04 and it's ok.
Good Luck
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 08-01-2010, 12:14 PM
The installation failed, but we are ok now. We reinstalled 8.0.0 without launching, and then installed 8.0.4 on top of it and 8.0.4 launched fine.
Thanks
-Box
Installing PT HD 8 on Snow Leopard Davidwilson macOS 4 02-26-2014 03:57 PM
Installing PT 8 LE on Snow Leopard adam79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-16-2013 11:33 AM
Installing PT 7.3 LE on Snow Leopard - Mac OS X 10.6.8 adam79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-14-2012 07:13 PM
MacBook Pro w/ snow leopard + Installing/upgrading fbmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-31-2010 06:53 PM
PTLE 8.0 with Snow Leopard: Disc Ejects w/o installing SoboJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-04-2009 11:28 AM
