Old 05-01-2018, 02:09 PM
vajoiner_ vajoiner_ is offline
Default Consolidating
Just a had a quick question. So when i go and consolidate all my tracks will the tracks that i have panned left and right stay left and right? Also will the clips that i separated and adjusted the volume of slightly in a track remain the same volume after consolidation? Thanks yall
Sent from my SM-J727T1 using Tapatalk
Old 05-01-2018, 02:34 PM
BScout BScout is offline
Default Re: Consolidating
Consolidate leaves all panning automation, volume the same. Nothing is made permanent. Only things like clip effects/clip gain/fades/edits are made permanent. So if you adjusted clip gain and edited clips and consolidate them all together, you will end up with one file with the different clip gains made permanent. Basically: after doing a consolidate, it will sound exactly the same as before consolidate as long as you leave it in the same track but now as a solid file with everything zeroed out (clip gain goes back to default, no clip effects, no fades since they are now baked in, etc)
If you want to apply automation (panning, volume), you need to use bounce.
Old 05-01-2018, 02:43 PM
So those tracks that are left and right wont stay left and right after consolidating? But the clip gains fades and edits will stay? Sorry i know you just answered this lol just trying to be clear lol thanks again
Old 05-01-2018, 02:53 PM
The panning stays with the track (track automation) not the clip. Consolidate works on the clip. So if the consolidated clip is still in the same track, the panning will still be the same.
Moving the clip to a different track (unless you have "automation follows" turned on and wrote the panning as automation) the panning will not be there. If you want those things to become part of the new audio file, you need to bounce.
Those get baked in with a consolidate (made permanent) to the new consolidated clip.
Old 05-01-2018, 03:02 PM
Perfect thank you!
Consolidating basslik macOS 6 11-02-2013 12:41 PM
Problem with consolidating... barstool719 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-11-2009 08:33 AM
Consolidating Audio DigidudeFL Pro Tools TDM Systems (Mac) 9 06-28-2005 03:59 PM
consolidating files Dead River Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-18-2001 04:20 PM
consolidating surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-28-2001 09:54 AM
