  #5001
Old 11-15-2012, 01:14 PM
unclemonkey unclemonkey is offline
Default Re: i7 Builds - Specs and Results
Time to move on from the trusty old Q6600. Anyone care to look over this list? only thing I'm keeping from the old computer is a bunch of Caviar Blacks for samples and audio.
Not sure about the RAM I picked. couldn't find any qualified 32 gig kits on Newegg. 32 gigs overkill? I suck at picking out RAM. Don't know much about Ram speed, timing.....
Not sure about the video card either. Figured I would go with something fanless and cheap. The one I picked looked like it wouldn't get in the way of to much in the case.
Not 100% on the MB. Any advantage going with one of the Asus Boards? (P9X79 or Sabertooth)?
GIGABYTE GA-X79-UD3 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813128532
-$30.00 Instant
$20.00 Mail-in Rebate Card
$269.99
$239.99
http://http://www.newegg.com/Product...82E16813128532
Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K
Item #: N82E16819116492
$569.99
http://http://www.newegg.com/Product...82E16819116492
Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
Item #: N82E16835608024
-$5.00 Instant
$94.99
$89.99
http://http://www.newegg.com/Product...82E16835608024
CORSAIR Vengeance 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMZ32GX3M4A1600C9
Item #: N82E16820233303
$165.99
http://http://www.newegg.com/Product...82E16820233303
ASUS 8400GS-1GD3-SL GeForce 8400 GS 1GB 64-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
Item #: N82E16814121484
$32.99
http://http://www.newegg.com/Product...82E16814121484
CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Full Modular ...
Item #: N82E16817139015
-$10.00 Instant
$199.99
$189.99
http://http://www.newegg.com/Product...82E16817139015
SYBA Add-On Card Model SY-PEX30016
Item #: N82E16815124107
Return Policy: Standard Return Policy
Protect Your Investment (expand for options)
$24.99
http://http://www.newegg.com/Product...82E16815124107
Microsoft Windows 7 Ultimate SP1 64-bit - OEM
Item #: N82E16832116997
Return Policy: Software Standard Return Policy
$189.99
http://http://www.newegg.com/Product...82E16832116997
Intel 330 Series Maple Crest SSDSC2CT180A3K5 2.5" 180GB SATA III MLC Internal Solid State Drive (SSD)
Item #: N82E16820167122
-$5.00 Instant
$154.99
$149.99
http://http://www.newegg.com/Product...82E16820167122
iStarUSA D-400-7P Black 1.2mm SECC Zinc-Coated Steel (Japan Made) (Main Chassis) 4U Rackmount Compact Stylish Chassis
Item #: N82E16811165418
-$10.00 Instant
$106.99
$96.99
http://http://www.newegg.com/Product...82E16811165418
Grand Total: $1,795.97
  #5002
Old 11-15-2012, 01:19 PM
Dism Dism is offline
Looks pretty good to me.
Although, you probably don't need to go that big with the PSU, just saying. Not that you can ever have too much power, but I spent $60 on mine and it still has plenty of juice to spare.
In fact, I'd go as far as saying spend a little less on the PSU, and a bit more on a modern GPU. Not that you need a lot a of video power, but a $60 DDR5 card will be a lot more future proof.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
  #5003
Old 11-15-2012, 03:37 PM
1 spot where we would differ. I always say buy the best psu you can afford and skimp on the vid card
I would also consider getting w8 instead of 7. As it will be the path going foward. Obviously not ready to go for PT yet though...... Like being stuck in a terrible state of OS purgatory!!!!
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #5004
Old 11-16-2012, 11:08 AM
I couldn't find a fanless DDR5 Video card on Newegg. If anyone could suggest a better card than the one I listed it would be appreciated. Im going to stick with the big power supply either way and W7 for the time being.
  #5005
Old 11-16-2012, 11:15 AM
-$30.00 Instant
$269.99
$239.99
$569.99
-$5.00 Instant
$94.99
$89.99
$165.99
$32.99
-$10.00 Instant
$199.99
$189.99
$24.99
$189.99
-$5.00 Instant
$154.99
$149.99
-$10.00 Instant
$106.99
$96.99
Still not sure about the RAM and MB. I'm going to look a little closer at the Asus boards and see if I can match up the ram better. I'm not trying to cut any corners. I want this as painless as possible. A few hundred more wont kill me. As all ways any suggestions are welcome.
  #5006
Old 11-16-2012, 03:57 PM
That vid card is cheap enough I wouldn't worry about it. I have always used similar cards since I don't use my daw for anything else. If you had to replace it in 2-3 years, no big deal.
pro-tools-pc.com
Intel I7 9900k
Win 10
  #5007
Old 11-16-2012, 03:59 PM
I would think the Asus sight would have approved ram.even if its not 1 set, buy a couple sets of something that's approved to get the amount of ram you want.
pro-tools-pc.com
Intel I7 9900k
Win 10
  #5008
Old 11-20-2012, 08:54 AM
mykhal c's Avatar
mykhal c mykhal c is offline
new PT10 build i just did for a buddy of mine. didn't run a DVERB test but man the rig is damn fast!!! the only 'gotcha' i ran into was usin' the SSD as the OS drive on the ASUS mobo with the new UEFI bios interface. there is a bios change that has to be made in order to avoid the OS partition bein' formatted with a GUID table vs the normal MBR table. before i figured it out the OS did run normally under the GUID format but it did NOT have a drive letter associated with the OS drive when viewing it under 'computer' services...tho the C drive letter did show up under disk management...kinda weird. but once i troubleshot things all went according to plan. SUPA BAD BUILD!!! i want one...NOW!!!
LIAN LI PC-7HX Black Aluminum ATX Mid Tower Computer Case
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
CORSAIR Vengeance 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMZ32GX3M4X1866C10
SAMSUNG 830 Series MZ-7PC256B/WW 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
Western Digital WD Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Western Digital WD Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED
Microsoft Windows 7 Professional SP1 64-bit - OEM
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #5009
Old 11-20-2012, 01:48 PM
Doven Doven is offline
What was the total for the new build?
Also for those in the know, which video cards are better for this use. I want to use a dual boot set up (via hotswap). One for video and one for audio so I want a solid middle of the road video card.
  #5010
Old 11-20-2012, 02:02 PM
Also, has anyone here set up hotswap bays/drives before on these builds? If so what is your experience?
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
