Old 02-05-2009, 03:34 PM
Drunken Mixer Drunken Mixer is offline
Default Crackling DB-33
When I play back a midi track I created a while ago with a key part re-routed to the DB 33 that came with Protools 8 I hear a crackling noise. I only hear it on playback though, not when Im playing. anybody have anything similar or any thoughts on why it might be happening?
DM
Fear is The Mind Killer
Imac 2.66 GHz Intel Core 2 Duo
3GB Ram DIGI002 OS 10.5.6
PT8.1
Old 02-06-2009, 11:46 PM
Default Re: Crackling DB-33
Anybody? This is driving me nuts!
PT8.1
Old 02-07-2009, 12:14 AM
TOM@METRO's Avatar
Try reducing the velocity in the MIDI performance track.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-07-2009, 05:52 AM
Will Russell's Avatar
Will Russell Will Russell is offline
The MIDI volume info from PT7 does not translate well to PT8 unless the MIDI volume data was written to the track. Try reducing the MIDI volume of the track in question in PT8 to around 64 or so.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 02-07-2009, 11:06 AM
lwilliam lwilliam is offline
You may also need to increase the buffer size. I've found the DB33 crackles at the same buffer setting where other VIs seem to be fine...at least on my system.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 02-07-2009, 02:07 PM
Granitza Granitza is offline
Question Re: Crackling DB-33
I posted on this same DB-33 problem a few days ago, but none of the advice I got in that thread worked (including higher H/W buffer size). I also contacted Digi Tech Support (no answer yet).
Meantime, thanks Will Russell and TOM@METRO for the new suggestions! I'll try reducing the MIDI volume and the MIDI velocity and see if that helps.
Here's my previous thread on this topic:
http://duc.digidesign.com/showthread.php?t=238269
Old 02-07-2009, 02:36 PM
Unhappy Re: Crackling DB-33
Well, I reduced the MIDI volume, and that didn't work. I reduced the MIDI velocity, and that didn't work. Still crackling.
The crackles are most noticeable when the note changes, or when the mod wheel is changed. When a note or chord is held, there aren't crackles.
Old 02-09-2009, 08:59 AM
Kling3 Kling3 is offline
Well now I'm getting crackling. I have a basic midi drum beat going thru Expand with two acoustic gtr tracks grouped together. I'm getting crackling on play back thru the headphones bus sent to my Rane HC6. Doesn't seem to matter what bus I use. I have low latency off and buffer set to 32. Increasing to 512 and using low latency reduced the crackling somewhat but I'm still hearing it (thru the 002r phone out) as low latency mutes the bus on record.
Mystery. I'll keep playing with this, however all serious recording has come to a screeching halt.
002r/MacPro 2.8/8-core/10.6.4/PTLE 8.0.4/two internal 500gig drives/8GB ram.
Old 02-09-2009, 02:46 PM
I duplicated another session exactly and re-recorded everything in the order I did the last one. No crackles. The only thing I did notice... with the one that had crackles, I recorded the acoustic on two grouped tracks that were set to "ticks" instead of "samples" ...would this matter?
Again the only time I hear the crackles on the 1st one is when monitoring thru the headphones bus (as was set up from a digi template).
Old 02-09-2009, 03:11 PM
DigiTechSupt's Avatar
Are you possibly working at 96k?
Avid Audio Tech Support
Support FAQ
Playback Crackling storeya 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-02-2012 02:56 PM
Crackling shiverbane Windows 3 04-18-2011 05:38 PM
Crackling Pop - Please help tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-13-2008 10:03 AM
crackling on 192 dhitz Pro Tools TDM Systems (Mac) 0 04-07-2008 12:09 PM
why crackling? mariushfm Digidesign Hardware & Software 4 04-10-2003 01:33 PM
