Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 08-30-2020, 02:56 AM
housemusicjunky housemusicjunky is offline
Default Mbox 2 and PT 2020.5?
Hey guys, i've been under a rock for a while...a long while. Started with PT 7 that came bundled with my Mbox 2. Used PT 10 for a long time and just now got PT 2020.5 after my computer finally died after almost 10 years! So am i reading correctly that the Mbox2 will not work with the latest PT version? The mbox 2 green light wont even power up. Is there a fix for this? If not what do you guys recommend as a good alternative interface. Thanks
Old 08-30-2020, 03:14 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Mbox 2 and PT 2020.5?
I'm afraid you are out of luck Mbox2 driver support info here.
Janne
Old 08-30-2020, 08:20 AM
The Weed's Avatar
The Weed The Weed is online now
How much I/O do you need and what's your budget? That will determine suggestions.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-30-2020, 08:39 AM
JFreak's Avatar
... and what kind of quality you expect. Because it is very easy to suggest something modular such as Apogee Symphony mkII but it is far more expensive than any Mbox ever
Janne
Old 08-30-2020, 08:58 AM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Drivers of MBOX2 aren't incompatible with the las 3 MAC OS, Mojave, Catalina & Big Sur and on PC With the release of Windows 10 2004 This Drivers from MBOX2 Crash all System!!! Probably you'll need a brand new Interface.... My MBOX2 is like a part of the decoration on my home Studio
Cheers
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 08-30-2020, 09:53 AM
I was cool with the 2 i/o of the mbox. I only do simple 1 or 2 mic hand drum and various percussion recordings at home. All bigger projects are done in a proper recording studio. Thanks
Old 08-30-2020, 03:10 PM
The Weed's Avatar
Audient, Focusrite, Mackie, Steinberg and others have affordable 2 I/O interfaces. Farther up the food chain would be Apogee, RME, UAD and others. Do some research and find user reviews, not just about the interface, but its drivers too. Another consideration is the interface's connection. If you don't have USB-C and/or Thunderbolt ports, any interface with that is out.
SonoBus
Old 08-30-2020, 06:07 PM
This link will be a good starting point to finding an audio interface to replace your Mbox2. I am assuming you want to stay with a 2 channel and a USB connection. If not, you can search with different filters.
https://www.sweetwater.com/c695--USB_Audio_Interfaces
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 08-31-2020, 09:59 AM
Thanks everyone, i ended up getting the Focusrite Scarlette 2i2. Has the basics i need for home use
Old 02-14-2023, 10:01 PM
Muziekschuur Muziekschuur is offline
The Ploytec driver would have been another possibility. But that would mean money down the drain after Catalina I think.
https://www.usb-audio.com/download/
BAG END gives THE BEAT!!
Mbox Pro 3 on Windows 10 with Pro Tools 2020.3 unkJE FireWire & USB Audio Interfaces (Win) 8 05-02-2021 01:11 AM
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Avid Control App Rollback (2020.5 to 2020.3) budster Avid S1, S3, Dock and Control App 2 06-09-2020 11:01 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
