Old 04-04-2012, 12:57 PM
relaxo relaxo is offline
Default Video of My Custom PT Quickeys Key Command Shortcuts
As a long time user of Startly's Quickeys custom shortcut key commands program, I've built up a cool library of helpful tricks. Here's a two minute video showing some of them:
http://www.youtube.com/watch?v=loUWIGoonlI
If any of you like these, I can zip up my shortcut sets and email them to you. I also have a large collection of QK shortcuts assembled from other Pro Tools Quickeys users that I can include as well.
Important notes about the Quickeys shortcut sets that I can email to you:
1) because Avid is often changing the menus and the menu item names, these shortcuts may need manual adjustment before they work with your version of Pro Tools. However, once you study the programming behind each shortcut it will be easy to make the adjustments to work with your system.
2) The shortcuts in "the DUC user collection set" are mostly in Quickeys v3 format which will open up in QK v3 and v4.
3) The shortcuts in "the relaxo set" that I will email you are in Quickeys v4 format and programmed specifically for PTHD 10. software. I don't believe these will open up in Quickeys v3, but you can try. These are all of the shortcuts shown in the video above. You can easily make them work in your system if you have QK v4 and ANY version of PT, v8 or higher.
4) All of these shortcuts sets were made on a Mac. I do not know if they can be used on a PC.
Old 04-04-2012, 01:17 PM
Emcha_audio's Avatar
Default Re: Video of My Custom PT Quickeys Key Command Shortcuts
That's pretty nifty, is that program available on PC? Since you're on mac, those on pc would probably have to do some editing to get the short cut working, but that's some great SC there.
Manny.
Wave-T.com
Old 12-23-2012, 05:06 AM
I still have this Quickeys shortcut set to email out if anyone would like it.
Old 12-23-2012, 07:21 AM
Meads Meads is offline
I've been using Quickeys for many years now. Couldn't live without it. It really speeds up the workflow, and the possibilities are unlimited.
I highly recommend it to everybody, who uses PT on a daily basis.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 12-23-2012, 10:42 AM
Is there a Quickeys version for ML? Startly's web page says it's not for Lion or ML.
Jack
QAPLA!
Old 12-23-2012, 10:54 AM
I know the website says so, but I have no issues with Quickeys 4 on 10.8.2.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 12-23-2012, 10:57 AM
http://forums.startly.com/community/...php?f=3&t=3289
Avid should get one of their guys on this since Pro Tools really needs QuicKeys for a lot of the functions I do
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-04-2013, 03:54 AM
mhmh mhmh is offline
Does anyone else use Quickeys 4 on Mountain Lion? I´m just upgrading my HD3 PPC System to HDX and really need Quickeys all the time.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 02-04-2013, 04:12 AM
I use it on two different rigs, believe me, it's working. If you want you can drop by and see for yourself. I'm in the neighbourhood.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-04-2013, 04:24 AM
Thanks, I sent You a PN
www.3-p.de
www.imglashaus.de
Digi/Avid: Why did my custom key command shortcuts stop working with 8.03cs1 ilovemyssl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-15-2010 08:21 PM
disable triggering Quickeys Shortcuts when typing in text... clusterer Pro Tools TDM Systems (Mac) 2 02-16-2010 04:27 AM
PT 6.7, KB Shortcuts, QuicKeys [Heads Up] Andre Knecht Pro Tools TDM Systems (Mac) 2 11-02-2004 03:25 PM
Share Your Quickeys Pro Tools Shortcuts Here! tomhartman Pro Tools TDM Systems (Mac) 17 10-10-2002 07:47 AM
What Quickeys shortcuts do You use? Tim R. Tips & Tricks 2 12-08-2000 11:20 PM
