M-Powered stucks as a process in XP and does not start
I have a problem with M-Powered 7.4 on an XP System. Before this week everything was fine (Using a Dualcore with M-Audio Projectmix I/O) Now, if I start PT the system is shortly loading, but not starting the program. When looking at task manager m-powered is displayed as a process, stucking at 30mb memory usage and 50% CPU usage. But there is no PT application running. I really did nearly everything to fix this. Un- /Reinstalled the whole program, with all hidden folders. Un- /Reinstalled all Plugins Update ilok Drivers Update M-Audio Drivers nohing changes. Did anyone has a clou about that issue? Maybe something is blocking PT? I really need PT nearly every day. Thanks Bastian |
Re: M-Powered stucks as a process in XP and does not start
i also have very similar problem on my desktop, but theres no problem my macbook duel boot in OSX and XPsp2
however in my situation, it doesnt suck up any cpu power i have used Mpower 6.9 on my desktop before which worked fine but anything after V7 would not start perating System: Microsoft Windows XP Professional 5.01.2600 Service Pack 2 Report Date: Tuesday 25 December 2007 at 22:53 ------------------------------------------------------------------------------------------ <<< System Summary >>> > Mainboard : Asus A7N8X2.0 > Chipset : nVidia nForce2 Ultra 400 > Processor : AMD Athlon XP @ 2200 MHz > Physical Memory : 1536 MB (3 x 512 DDR-SDRAM ) > Video Card : ATI Technologies Inc Radeon 9200 Series (RV280) > Hard Disk : ST3120026A (120 GB) > Hard Disk : ST3200822A (200 GB) > DVD-Rom Drive : BENQ DVD LS DW1655 > DVD-Rom Drive : HL-DT-ST DVD-ROM GDR8162B > DVD-Rom Drive : SCSIVAX DVD/CD-ROM SCSI CdRom Device > DVD-Rom Drive : SCSIVAX DVD/CD-ROM SCSI CdRom Device > DVD-Rom Drive : SCSIVAX DVD/CD-ROM SCSI CdRom Device > DVD-Rom Drive : SCSIVAX DVD/CD-ROM SCSI CdRom Device > DVD-Rom Drive : SCSIVAX DVD/CD-ROM SCSI CdRom Device > Monitor Type : 20020712 17TFT LCD MNT - 18 inches > Monitor Type : 20020712 17TFT LCD MNT - 18 inches > Network Card : Nvidia Corp nForce MCP-T Networking Adapter > Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 2 > DirectX : Version 9.0c (March 2006) PCI: two UAD-1, one powercore, one TI firewire card
theres no right or wrong only like and dislike http://www.soundclick.com/bands/defa...?bandID=268740 |
hay man i think i have a solution for you. I noticed this happening to me but strangly enough i found its is running fine after all.
i got around it like this Click Alt+tab (Allows you to skip through open alpplications) and you should find the protools icon as one of the open applications. Just keep pressing tab till protools is highlighted then let go of both buttons. it should apear again. Let helped me anyway and it seems like it maybe the same fault. Very strange |
thanks for the input, but that wont solve my problem
doing so can lead to weird results. i would start with that first, remove one memory stick, and just run a pair of them. ------------------------------------------------------------------------------------------ make sure you are using a digidesign approved firewire card (built-in motherboard firewire is not sufficient). ------------------------------------------------------------------------------------------ try to remove the SCSIVAX DVD/CD-ROM SCSI CdRom Device ------------------------------------------------------------------------------------------ FireWire Connections A 1394 ("FireWire") controller/interface is required to connect an M-Audio FireWire interface to your computer. Some computers have built-in 1394/FireWire controllers, while other computers require an add-in 1394/FireWire controller card (purchased separately) Some built-in 1394/FireWire ports may be incompatible with Pro Tools. if you experience FireWire-related issues or errors when using the built-in 1394/FireWire ports on your computer, Digidesign recommends installing a Digidesign-Qualified 1394/FireWire card. The following PCI FireWire/1394 Controller PCI cards have been qualified by Digidesign for use with FireWire hard drives and M-Audio FireWire peripherals with Pro Tools M-Powered software: ADS PYRO PCI 64 - Part Number: API-311 - Bus type: 64-bit PCI SIIG 1394 3-port PCI i/e - Part Number: NN-440012 - Model Number: NN2608 - Bus type: 32-bit PCI ------------------------------------------------------------------------------------------ if you want REAL help, then post SANDRA info (so we can see more detailed info).
http://www.myspace.com/blaqmusicgroup |
I had a similar issue upgrading from 7.1 to 7.4
At first audio was stuttering, then PT would get stuck at "DAE Loaded" every time I tried to open it. I used the m-audio setup (MP_WDM_5.10.00.3516.exe) to remove the m-audio software and drivers, ran it again to re-install, and now PT7.4 works like a charm. Hope it works for you.
Cheers, Angelo Quaglia |
bseelbach... create a new login and try running pro tools from there. This may fix your problem.
It won't, however, permanently fix your problem. See my post here for details on how this is a consistent, on-going problem that digidesign needs to fix. WATYF |
Pro Tools 9 installation stucks | S-Style | Pro Tools 9 | 5 | 04-23-2012 07:34 AM |
W7 wont start with 002 powered up. | Jay002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-05-2011 07:01 AM |
PT 7.1 M-Powered won't start | bamim2 | Pro Tools M-Powered (Mac) | 0 | 07-11-2011 11:11 PM |
Pro Tools 9.0.2 update installer stucks | firenike9 | macOS | 25 | 04-29-2011 07:34 PM |
How to start fresh with M-Powered on new IntelMac? | jccrtv | Pro Tools M-Powered (Mac) | 2 | 07-28-2006 01:58 PM |
