Old 12-02-2020, 06:00 AM
sleshnyc@gmail.com sleshnyc@gmail.com is offline
Default Waves L3 prevents bounce
running pt 2020.9. I put waves l3 in the master buss, and went to bounce. The file was created but it was blank. Silent. Removed waves, and everything fine. Any have this happen to them? Running Waves 11 since i dont' have the metal compatible card, but that shouldn't be the issue.
Old 12-02-2020, 08:28 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Waves L3 prevents bounce
I tried with L3 Multimaximizer. Bounces as expected. I'm on V12.
Have you checked if the issue is just L3 or all Waves plugins?
Stephen
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
Old 12-02-2020, 06:29 PM
Stephen
so it also did it with maxim. as in, bounce was blank. removed maxim, no problem.
Old 12-02-2020, 06:41 PM
JCBigler's Avatar
JCBigler JCBigler is online now
I use L3 on almost all of my mixes and mastering sessions. No effect.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / HD|Native-TB / Protools Ultimate 2020.5
Home/mobile: Focusrite Red 8Pre / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 12-03-2020, 01:23 AM
Trash prefs is my guess?
Stephen
Old 12-11-2020, 06:21 AM
simon.a.billington simon.a.billington is offline
Could it perhaps be the sample rate and/or dither settings that could be causing the issue??
Old 12-11-2020, 07:31 AM
Bookerv12 Bookerv12 is offline
I was having a similar problem:
When I would Offline bounce a song, it would go through the process, but upon opening the bounce, the last third of the audio was missing....Just a line.
No Waves plugs, but one Avid EQ and Massey L2007.
I thought it was the 007 as a bounce worked fine without it.
But, I tried activating the 007 and deactivating the EQ and that worked too.
Haven't had enough time to mess with everything, but can't use offline bounce for now.
PT2020 Ultimate, HD Native
bookerv12
Old 12-11-2020, 04:06 PM
Double-check your bounce source?
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 01-08-2021, 08:28 AM
Actually that’s a good point because one reason it “might not” be bouncing is if there are overs, maybe. It’s unlikely, but even though it’s a limiter, it’s not an ISP limiter. I doubt it would make difference, but if somehow you were exceeding 0dB, that might be cause enough for it to not render. Maybe.
HTML code is On
This pop up prevents me from starting Pro Tools grateful macOS 7 05-04-2017 06:47 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 04:55 PM
Axiom 25 prevents fader banking travistko MIDI 0 03-16-2009 08:31 AM
Assertion in line 525 prevents PT from launching JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-29-2007 02:59 AM
Autotune prevents PT startup smilez03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-28-2005 07:39 AM
