Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-26-2019, 08:47 PM
johnnyv johnnyv is offline
Default Offline bounce is going so slowly
Hi everyone,
I'm doing some offline bouncing to disk. I only have about 10 tracks, and I'm trying to bounce to MP3 format. I have 3-4 plugs on each channel; dialogue noise reduction, compression. My offline bounce speed is only 3-4x real time. I wonder why it's so slow? I think I'm using Izotope Dialogue De-noiser and Audionamix Dialogue noise cleaner. Maybe these types of processes slow down the bouncing?
Any ideas or thoughts would be greatly appreciated.
Old 11-26-2019, 09:30 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Offline bounce is going so slowly
Hi ! Some plugins processing slow down the offline bounce and i give you an example. When i use the Universal Audio BX V2 on mastering, offline bounce goes about 3.x and when i used the same plugin but native from Plugin Alliance bounce goes about 15.x , thats huge difference.
Sent from my SM-G973U using Tapatalk
- Jesus Alvarado -
Keep the volume UP !
Old 11-26-2019, 09:45 PM
Hmmm. Very interesting. I am using a UAudio plugin. Let me see if removing it helps. Thanks for the possible solution!
Old 11-26-2019, 10:08 PM
rinky rinky is offline
Overall, I've experienced slower-than-normal offline bounce since 2019.6.
PT Ultimate 2020.11
PT HDX
MacPro 7,1
16 Core
96 GB ram
OS X Catalina 10.15.7
Somehow, musicians are now technicians!
Old 11-26-2019, 11:35 PM
Blinkofani Blinkofani is offline
Using UAD will slow down because the process goes between your computer and the DSP chips in your Satellite or Apollo millions of time during the bounce down. I mainly use Logic and it's the same thing. The second there's a UAD plugin somewhere in the project, bouncing takes a lot more time. It's explained somewhere in the manual.
Blink
iMac 27" i5 w/24Gb ram, macOS 10.15.7, PT 2020.11, Logic Pro X 10.6.0, UA Arrow, UAD2 Satellite Quad TB
Old 11-26-2019, 11:58 PM
On the next pass, I deactivated the aux track that had the UA plugin on it, but nothing changed in the speed of the bounce. It was about 3x normal.
Old 11-27-2019, 12:16 AM
Sardi Sardi is offline
Noise reduction plugins are very CPU intensive. That’s pretty normal for it to be slow.
Deactivate the restoration plugs and watch it zip through the render.
Old 09-30-2020, 01:34 AM
latinbaum latinbaum is offline
Hi all,
I have the same issue with the offline bounce speed but it's always 2.3x or less... often 1.2x or 1.3x so it makes the feature practically irrelevant. I'm not using UAD plugins and would expect the RAM to be sufficient (128 GB). Whether I'm bouncing a full orchestral piece with 70 tracks or a small band with 12 tracks... it doesn't matter. Any ideas why?
Pro Tools Ultimate Version 2018.10.0
macOS High Sierra Version 10.13.6
Mac Pro (Late 2013)
Processor: 3.5 GHz 6-Core Intel Xenon E5
Memory: 128 GB 1866 MHz DDR3
Last edited by latinbaum; 09-30-2020 at 01:40 AM. Reason: Mistakedly duplicated info from the signature
Old 09-30-2020, 03:15 AM
What type of plugins are you using?
Old 09-30-2020, 08:10 AM
Many VI plugins will drag offline bounce down too. KeyScape is one such killer. I tend to commit those tracks as soon as I can during mixing.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
PT 12.5.2 Offline Bounce - Different Levels after Bounce ?? innenhofstudios Pro Tools 12 3 01-29-2018 09:56 AM
My kick bounce is slowly going off the grid over a long period DBK Getting Started 5 08-21-2015 08:49 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 04:55 PM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 06:58 PM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 10:29 PM
