Old 10-01-2014, 10:24 AM
ns456 ns456 is offline
Default PT 11 Initializing Audio Engine Restarts Computer
I Just got the Eleven rack and installed PT 10.3.9 and PT 11. PT 11 worked fine for a few days. I didnt install anything after that or did any system changes. PT 10.3.9 works fine but now when I run PT 11 it loads up until it gets to Initializing Audio Engine then my computer shuts down and restarts. I tried it with the Eleven rack connected and disconnected and the same issue exists.
I am running an iMac i3 12GB RAM.
Joe Naughty
Old 10-15-2014, 01:03 PM
Shan's Avatar
Shan Shan is offline
Default Re: PT 11 Initializing Audio Engine Restarts Computer
Have you tried launching PT 11 using just the built in audio of your iMac? Same issue when you change the audio engine?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-15-2014, 01:48 PM
Which is hold down the 'N' key while Pro Tools is starting and when the playback engine dialog appears then select 'Built-In Output" and what exact playback engine device name are you trying to switch to? And what exact version number driver have you installed for that device (presumably your Eleven Rack).
In general we need much more information than the crumbs provided. Starting with what exact iMac model/date code and exact OS X version and the Pro Tools 11 exact version.
You have Pro Tools 10 and 11 co-installed on the same iMac? Did you carefully follow Avid's coinstalled directions/requirements?
If OS X is crashing what is shown in the OS X Console.app under system crash reports. Paste the text of a recent crash report here from one of these events if you can find it.
Editor - Error Initializing MIDI Engine Michael North Eleven Rack 15 10-31-2020 10:48 PM
Pro Tools hangs at initializing audio engine kasman Pro Tools HDX & HD Native Systems (Win) 12 05-10-2016 10:20 AM
Help Freeze on "Initializing audio engine" jeml Pro Tools 11 1 03-07-2014 12:52 PM
Pro Tools 11 stuck on "Initializing Audio Engine" AudioDrummerGuy Pro Tools 11 10 01-19-2014 01:47 PM
PT 6.7 restarts my computer against88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-16-2005 05:14 PM
