Drop out\'s
I've used PT for many years and I've NEVER had this problem.
PT7 is giving me drop out's often..... as in every 10 seconds or so. I've checked and re-checked every Digi trick (prefs and buffer size and permissions, digi link cables, d-subs and on and on) Anyone have this problem with PT7?????? |
Re: Drop out\'s
I'm getting Drop-outs in 6.9.1 OS 10.3.8. Not nearly as often as you it seems, but it ruined a voice-over take yesterday. scary. It will start dropping out every 10 sec like you said every now and then but closing and reopening the project temporarily fixes it. Fortunately I use Logic Pro for most of my work which is working fine. Anyone know what might be the issue?
J dual gig quicksilver HD3 |
Re: Drop out\'s
Can you please post specific information on your system - computer model, OS version, drive types, etc?
The more information you can provide, the easier it will be for us to troubleshoot. |
Re: Drop out\'s
Sure,
Mac G5 dual 2.0. 4.3 OS HD 2 192 3 Seagate 300 gig drives All installs are clean since PT7. I've checked and re-checked all preferences, buffer settings and parameters. Pitched pref's. Verified and repaired permissions. Tried copying sessions to various drives including my application drive. I've checked the Digi-link cable and all d-subs. I've re-seated the cards. |
Re: Drop out\'s
G4 Quicksilver Dual ghz
OS 10.3.8 1 gig RAM Seagate 80 gig 7200 RPM IDE audio drive. Maxtor 7200 RPM 80 gig system drive HD3 Accel 192 (w/ rosetta 800 connected via Xmix card to legacy port) 192 Digital 96i i/o 2408mkiii I did not have the drop out problem with 6.7 and OS 10.3.7 I record to the Rosetta. Drop out occured while recording only one track with no other tracks in the project. thanks, Judson |
MIDI out's EMULATED? | reshp1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-27-2010 08:47 AM |
Analog Out's on 0003 Factory | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-15-2009 01:15 PM |
Need more In's / Out's | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-08-2006 08:44 AM |
I'm on the analog out's.... | guitpicn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-08-2006 06:42 PM |
Fade Out's . . . | JEdmunds | Tips & Tricks | 1 | 06-26-2001 07:42 AM |
