Old 05-17-2018, 08:36 AM
Audioartist Audioartist is offline
Default Adjusting plugins from S3 controller (S3L-X)
If I have for example a saturation plugin inserted om my reverb return, how do I get to adjust med reverb parameters without using the mouse?
When I hit insert I am just getting to the saturation plugin, even if a press select+insert.
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T
HD native thunderbolt
PT10HD 10.3.8. - PT11HD 11.3.2
2xHD madi - 2xHD omni -
Old 05-18-2018, 08:33 AM
emluper emluper is offline
Default Re: Adjusting plugins from S3 controller (S3L-X)
Make sure you're selecting Inserts from the Global Control encoders on the upper right side of the S3 BEFORE you select the FX Return channel. You should be able to access the Reverb first that way. I'll double check it myself when I get a chance.
glitch in sound when adjusting plugins mikeyman Pro Tools 10 10 03-04-2014 07:52 PM
Adjusting several plugins together. Audioartist Pro Tools TDM Systems (Mac) 2 02-11-2012 10:03 AM
Controller for Plugins deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-12-2007 09:55 AM
Best Controller for Plugins deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-08-2007 02:00 PM
using two softs plugins with the same controller Kelso MIDI 0 12-09-2004 10:44 AM
