  #151
Old 11-01-2017, 09:06 PM
Default Pro Tools MTRX
You are comparing a new product and a product at its end of life. And when Avid runs down the HD IO they can lower the price of the MTRX.
Do I need to draw a picture... Avid has exited making interfaces, the HD IO will be their last. They no longer have the technical resources to develop interfaces, and exiting that may be the best idea anyhow. They are now rebadging other companies products. Same in the video space. Anybody’s equipping a studio should think through what IO chassis they want to deploy and what one will be more flexible and have a long term future.
The HD IO is not competitive against products like the Apogee Symphony (more flexible, twice the density), and Avid needed a story with monitoring control etc. and seemed to have made a good decision. Hopefully as well the Dante story will become more important in future.
And that pricing comparison is not quite fair as the MTRX chassis has more IO expansion/flexibility compared to a HD IO.
If you want lowest cost 16x16 class IO there are lots of options out there, including non DigiLink interfaces. The HD IO just dies not look that competitive, say compared to an Apogee Symphony II or some similar products.
  #152
Old 11-05-2017, 06:21 PM
Fidelis Fidelis is offline
Default Re: Pro Tools MTRX
I doubt they are going to lower the price of the MTRX anytime soon... even if HD i/o runs out.
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 20GB RAM, OSX 10.10.5, PT HDX, PT 12.8, SSL 4040G+, tons of outboard
Mac Book Pro 2.4Ghz Duo, 4GB RAM, OSX 10.10.5, PT Vanilla 12.8
  #153
Old 11-18-2017, 10:18 AM
MatzeHD MatzeHD is offline
A important question, has the MTRX a radiator fan, like the other I/O Boxes on the side? If yes, how noisy is the fan?
Because, the fan from the I/O Box was still ok, a little bit louder as a good pc, but I dont needed a special cases!
I hope the MTRX is silent? :)
  #154
Old 11-20-2017, 04:10 PM
dr sound's Avatar
dr sound dr sound is offline
There is no fan on the DAD AX32 which is what the MTRX is made from.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
  #155
Old 11-21-2017, 09:27 AM
LukeHoward LukeHoward is offline
Pretty sure I saw/heard a fan in my MTRX – also according to the DAD manual, there are two “Ultra low noise internal fan with speed adaptation
to the temperature”.
  #156
Old 11-21-2017, 09:34 AM
dr sound's Avatar
My answer is "There is no fan" on the side like MatzeHD asked about.
Unlike the 192's there is no fan on the side. If there is a fan internally it is
barely audible... EVER! If you have to look it up in the manual then you already have your answer. A fan is not an issue with the MTRX or DAD AX32.
aka dr.sound
www.thedubstage.com
  #157
Old 11-21-2017, 09:37 AM
Heh, fair enough I'm still putting mine in a machine room!
  #158
Old 12-16-2017, 06:19 PM
Question/possible feature request: is there a way for the sync source/sample rate/adapt to to be associated with a monitor source? I'd love to be able to select my CD player as a source without having to change DADman configurations, or having to insert a sample rate converter between the CD player and the MTRX. (Usually I'm running of the MTRX's internal clock at 96k.)
  #159
Old 12-21-2017, 01:59 PM
BScout BScout is offline
How are you inputing the CD signal into the MTRX. The add-on AES card has auto SRC (not the built into the box AES though)
As far as I can tell, much of the Pro Mon side does not talk to the DADman Conf. I think it'd be quite complicated to define what is "an input source" seeing as any input can be one and you can have any output (or multiple outputs). If I route two different sample rate input sources to two different outputs, what would take precedent? It would get confusing. Unlike something like a Grace m906, you can have multiple inputs and outputs active and controllable so there's no one-to-one input to output relationship.
I do know that if you have mismatching clocks on input sources while the "sum" option is selected, it'll change to switch mode for the output monitoring.
  #160
Old 12-21-2017, 02:04 PM
Just the built-in AES. The add-on AES card would be an expensive solution to this problem
Hmm, that's a fair point, not sure if there's an elegant solution to this.
