Old 04-06-2010, 01:33 PM
Propanemusic Propanemusic is offline
Default MIDI Input/Output showing NONE Still!!!!!!!!!
I have all MIDI cords connected right but when I try to record MIDI from my Fantom, nothing shows and when I go to MIDI studio the I/O ports show up NONE I cant get Protools to SEE my fantom. My problem is that I have checked the forums and all they say is to make sure MME refresh is running, and IT IS, still no fix.
Please help!!!!
Old 04-06-2010, 02:54 PM
Electric Nick Electric Nick is offline
Default Re: MIDI Input/Output showing NONE Still!!!!!!!!!
I'm having the same problem Propanemusic.
The only way I got my midi ports to start working again, was to completely uninstall Pro Tools and all drivers, and then re-install it.
The Problem is...that only worked for about a week and a half and then my midi ports disappears again.
I'm using a Digi002 Rack and the midi lights are lit up on the front and when I press a key on my synth, the light flickers rapidly as it always has. It's just that the midi ports disappear in the software. I'm guessing it's a driver issue cause even when I load up another DAW, they midi ports on my 002R are non-existent still. Only controllers I connect through USB appear.
Asus P8P67 Pro 3.1 / Intel i7 2600K / GSkill 2x4GB 1600 / Win 7 Pro 64bit / PTLE 8.0.5 / Digi 002R / Reason 6 / Akai MPK61 / KRK V8's / Rane TTM56 / Technics 1200 mk5 / and Stacks of Wax!
Old 04-06-2010, 03:33 PM
kdubyou kdubyou is offline
I'm taking a shot in the dark here...
It's been a while since I looked at this but, as I recall, the Fantom (mine is an X, not a G) uses USB in either storage mode or midi mode. I think setting it up one way or the other can have implications for the midi in and out jacks on the Fantom. Page 218 of the Fantom manual.
Hope this helps.
Kevin
Gigabyte GA-P35-DS4; Q9650; Win 7-64; Saffire Pro 40; PT 12 / MacBook Pro C2D 2.66; 10.10.3; PT 11.3.1
Old 04-06-2010, 03:54 PM
stickboymusic stickboymusic is offline
im not on my computer right now so trying to remember the correct wording
but have you gone to midi menu
then ticked the "slave" box
then see if your controller shows up in the send/recieve drop down boxes?
Old 04-06-2010, 11:13 PM
Also, under the Options menu(I think) in PT, you should check Midi Thru(enable it). You could also try going to Midi Studio Setup and adding the Roland as an instrument/device.
Old 04-07-2010, 06:49 PM
egrims egrims is offline
I have the exact same problem that you list here. I have a Technics digital piano that only supports MIDI (no USB MIDI) and lights up the front of the 002 Rack but I don't get the 002 Rack to show up in the MIDI Studio setup. Even uninstalling / reinstalling did nothing to help that setup.
I have an M-Audio Keystation 88 Pro that is hooked up through USB and it sees this no problem and have not had any issues with this so far. I'm running 8.0.3 on Snow Leopard 10.6.2.
Old 04-08-2010, 12:29 AM
I can't figure out what the problem could be. I can Sync the Fantom and Protools together, but can not record MIDI as there is no Input or Output to select in MIDI studio. ???? I see that a lot of people have this issue why isn't there a fix? MIDI is a HUGE reason I purchased the Mbox2. Now I have a $2,000 Fantom keyboard that I can't record MIDI from. Please someone at Digidesign HELP US!!!!!!!!!
Thanks
Old 04-08-2010, 12:46 AM
Jermak Jermak is offline
Everytime you install PT it seems to lose MIDI - Just check that you have the boxes ticked under midi filter (in and out) or install Reaper
Win7x64
PT 9.0.5 DIGI003 Digimax FS
ASUS P5E Q6600 6GB
Eleven Rack + EXRP
Old 04-08-2010, 12:55 AM
MikeLip MikeLip is offline
me too.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 04-08-2010, 02:12 AM
I installed the Trial Version of Reaper yesterday. After 2 hours of playing with it tonight, I can promise you that I'll be buying the license! Bye Bye Pro Tools, it's been a fun, but rough 5 years!
I still think this is driver issue though. Cause the Midi Ports don't appear in Propellerhead Record, or Reaper. But the Midi lights on my 002R hardware are lit up and respond to the midi triggers from my Roland V-synth as they always have.
This could be a problem directly related to the fact that I'm using Vista 64-bit which is still (surprisingly) not supported yet. I never had any problems with my midi while on my PPC G5. But had to sell it cause I realized I better get some money out of it before it's worth nothing.
I was gonna keep my 002R and use Reaper/Record/Reason with it, but after these Driver issues on 64-bit...I think it's the next thing for sale. (as well as my Structure Full, Velvet, Smack, Pultec, iLok, etc)
Peace, and best of Luck!
Mic/Line 1 and Output 1-2 not showing up in audio input path selector gelianamrie Windows 4 08-02-2012 05:29 PM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 04:33 PM
002R not showing up in midi output selector in PTLE 7.0 Mcgrathx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-21-2008 04:23 PM
M-Audio 02 not showing on Midi Input Enable window... jns2005 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-10-2007 04:22 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 04:20 PM
