Old 01-02-2009, 07:36 AM
moneyp moneyp is offline
Default Sync I/O not recognized on Windows Pro Tools HD 7.4
For some reason my Pro tools HD 7.4 will give me the warning: Unable to establish communication with the Sync box when trying to enable sync options.
By Chosing Setup > Peripherals, and click the Syn-chronization tab and Click Enable SYNC I/O.
However it does show me the correct timecode when opening the Sync Setup software in windows - pro tools - utilities.
The sync I/O is connected via A custom Serial-to-COM cable. As stated in the Sync io guide.
Any ideas?
Thank you for your time,
Steve Pittoors
Old 01-02-2009, 06:33 PM
Bob Brown Bob Brown is offline
Default Re: Sync I/O not recognized on Windows Pro Tools HD 7.4
Steve,
When you want to use the SYNC with Pro Tools, you must connect the SYNC directly to the HD card.
The Windows SYNC Setup Utility needs to be connected via the custom dsub (9-pin) to mini-din connectors (I could be getting the names of those connectors wrong.) When you use this software, you need to connect to the computers COM port.
If you are running 7.4, almost all of the functionality of the Windows SYNC Setup Utility has been implemented in the Pro Tools Peripherals Dialog. The firmware can be updated using DigiTest.
Old 01-03-2009, 07:53 AM
BradLyons BradLyons is offline
Originally Posted by Bob Brown View Post
Steve,
I'd love to know how to get this to work--because I've NEVER been able to get my Sync I/O working when connected to the HD card. But when connected to the Serial Port on my PC, it works just fine.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Elevenrack not recognized on Windows 7 LarryWallwart Windows 0 11-29-2012 07:50 AM
MBox2 - USB / Windows problem - USB device not recognized / DIM lights galwanoskop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-22-2012 01:56 AM
projectmix not being recognized in windows vista anymore wreckthisplace Pro Tools M-Powered (Win) 3 10-24-2008 07:09 PM
Project Mix recognized but not sync with ProTools MusicalWonder Pro Tools M-Powered (Mac) 2 08-01-2008 07:29 PM
Mbox 2 wavedrivers not recognized by windows Glichout 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-03-2007 06:21 PM
