#31
Re: "SystemId Entered does not match the SystemId on record for this Serial"
Hey Darryl thanks mate that link resolved it for me and I was able to complete the firmware update!
I cannot thank you all enough!! removed IE11 and removed 1 update named IE11 and all was fine :) |
#32
When I try to upgrade my Eleven Rack I get the same fail message:
SystemId (XXXX) Entered does not match the SystemId on record for this Serial Number (XXXX) I'm running Windows 8.1 and although you can't uninstall IE11, you can turn it off in the programs list which I have done. This hasn't fixed the error however. My system is: OS: Windows 8.1 Processor: Intel i7-4770K RAM: 16GB System Type: 64-bit OS, x64-based processor Eleven Rack Firmware Version 1.0.3 Build 0.6.2.0 Any ideas? |
#33
#34
Would Windows 7 offer a different result? Thanks, Jon |
#35
I used a PC with Windows 7 and uninstalled IE on it. I got the same error:
SystemId (XXXX) Entered does not match the SystemId on record for this Serial Number (XXXX) What's my next move? Also is there a phone number I can call? The support page leads me around in circles. I'm starting to regret this purchase heh. Jon Last edited by Jtnorwood; 10-10-2015 at 09:34 PM. |
#36
#37
Let me create a case for your concern and will get one of our technical support representative call you back to help you with your concern. And just for a reference, our support line number is 650-237-1700. Best Regards, YD |
#38
Jon |
#39
This is resolved. The serial number was wrong and I used a Win 8.1 machine that further goofed up the process so yay.
Thanks for the help. |
#40
Hi Guys,
I`m new too and have exactly the same problem, I`m running windows 10 on one system and now have an 8 system sitting here which still tells me the ID/serials don`t match. Contacted support" Eleven expansion pack [Case : 02820953]" and the code they gave me said it had already been used. Think I need to lay down before it all goes out the window! |
Expansion Pack - SystemID? | jimst57 | Eleven Rack | 6 | 03-22-2011 01:12 PM |
*The serial number you entered has already been registered.????? | ElQueso | Pro Tools M-Powered (Win) | 3 | 05-14-2010 09:35 AM |
The serial number you entered has already been registered.?? | joerusi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2008 07:08 AM |
