Old 08-17-2018, 03:28 AM
espron espron is offline
Default DNS one controls "reversed" when in insert mode
When flipping the controls of the cedar dns down to the faders of an artist mix, the parameters spill out in the reverse order of the gui of the plugin, so that the level control which sits at the far left on the plugin maps to the the right-most fader. This is rather confusing, and on the S6 and D-command this does not happen. Anyone else seeing this?
Espen
IMDB
Old 08-17-2018, 05:27 AM
Cryos's Avatar
Cryos Cryos is offline
Default Re: DNS one controls "reversed" when in insert mode
In the Eucon software on the mac theres a new preference that allows you to reverse the order of the controls. I was having the same issue and this resolved it.
Cheers
Sent from my SM-N950W using Tapatalk
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 08-20-2018, 02:09 AM
Brilliant. Thanks!
Espen
IMDB
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Should I use the "h/w insert delay" feature with Symphony io in USB Mode? Blake Henderson Pro Tools HDX & HD Native Systems (Mac) 8 09-04-2011 11:38 AM
Switching a HD from "transfer only" to "record mode" BretFarewell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-16-2010 12:49 PM
Switching subwoofer from "discrete mode" to "stereo mode"? Slerker Post - Surround - Video 6 02-11-2009 07:04 PM
compressor on the "insert" or "in-Line"? Dead River Studio Tips & Tricks 6 06-08-2002 04:12 AM
