Old 08-02-2018, 09:05 AM
MNI MNI is offline
Default Artist Mix Cubase integration
I'm using Cubase 9.5 with the latest Eucon version and it seems that the Solo buttons will light up when I press them but they have no function (i.e. they don't actually solo the track)
Also, when I do solo using a mouse click, the solo button doesn't light up. It turns the "ON" button off for all other channels.
The mute (or "ON" buttons) work as they should except on VCA tracks. In which case I can't press the ON button to mute or unmute, and also whenever I solo using my mouse I get no visual representation on the Artist Mix.
Is this a known issue? Or am I missing anything regarding Cubase?
Old 08-03-2018, 05:38 PM
EddieJones's Avatar
Default Re: Artist Mix Cubase integration
That doesn't sound right, I'll get someone to test next week and report back.
Old 08-04-2018, 05:20 AM
MNI MNI is offline
That will be great!
I’ll be happy to share information in order to get this thing resolved.
Thanks!
Old 08-15-2018, 07:40 PM
MNI MNI is offline
Any news?
Old 08-19-2018, 10:44 AM
EddieJones's Avatar
I tested this myself and it all worked OK (with 9.5) I'm not sure what could be going on. Sometimes if there are network issues we see one-way communication issues but this would affect everything.
Old 08-21-2018, 08:23 AM
MNI MNI is offline
I wonder...
Because it seems to work fine besides that....
Could it be a network cable issue?
I'm not using a crossover cable. However, the connection feels reliable and fast.
What should I look into in order to resolve this?
Thanks!
Quick update:
Just tried it on my MacBook Pro and I'm getting the same issue...
Old 08-21-2018, 06:39 PM
EddieJones's Avatar
I'm not sure, you could try posting on Steinberg's forum if you haven't already. I'll keep thinking....
Old 08-22-2018, 04:07 AM
MNI MNI is offline
Thanks. I’ll do that.
I’ll give the crossover ethernet cable a shot anyways.
I’ll post an update once I tested it.
Thank you so much for your help!
Old 08-23-2018, 08:11 PM
MNI MNI is offline
Just a little update,
Tried using a crossover ethernet cable and nothing changed...
Will try to investigate further...
Please let me know if you find anything else.
Thanks.
Old 09-25-2018, 08:52 PM
MNI MNI is offline
Hi Eddie,
Still having the same issue...
Also every so often (on random projects), my Artist mix will stop communicating with Cubase and just freeze...
I have to power the unit off and on, restart the Eucon application, and restart Cubase in order to get them "talking" again, and then after a few minutes the artist mix will freeze again and cease to communicate with Cubase....
I did notice that in Cubase's device manager, the Eucon driver says it is Version 7.1.1.8 built on Apris 11 2017
Is this the latest version?
Or perhaps I have a version mismatch between Eucon and Cubase's "eucon.bundle" file?
Cubase 8 or 8.5 - Artist Mix not working / El Capitan 10.11.2 webber Artist Series 7 10-17-2016 02:01 AM
Artist Mix and Hidden Tracks in Cubase J-S-Q Artist Series 2 07-16-2014 03:51 AM
Artist series and cubase 7.5 trock Artist Series 12 03-11-2014 01:30 PM
Cubase 6+Artist robertg Artist Series 2 02-26-2012 01:12 PM
Registering Artist Control v2 with Cubase The Red Rooster Artist Series 0 08-01-2011 03:03 PM
