Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 06-18-2020, 05:29 PM
Default Accessing Talkback Mic post-TB switch
Hi there - Prefacing by saying that I'm very Pro Tools-savvy, but not very S6 savvy. Working with a client's system: Pro Tools HDX, S6, MTRX running on Mac OS High Sierra. Long story related to running remote their rig remotely, but I'm wondering if there's a way to get the talkback mic into a Pro Tools session *post* the talkback switch? I can access the talkback mic's input in I/O, but that's pre-switch - it would be very useful for me to be able to bring it in after the on/off switch. Yes, I can just bring it into a fader and use the mute switch but then don't get the monitor dimming. Any way to do this?
Thanks in advance!
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 06-18-2020, 05:47 PM
creativecontrol's Avatar
Default Re: Accessing Talkback Mic post-TB switch
This should do it.
Just make an additional monitor in your Monitor Profile and add a source - mine is called null and its connected to some mono source that is not connected. Output is the channel on DigiLink you want to feed into Pro Tools. TB Mode is set to TB Cut in this case.
Jeff
Jeff Komar
Old 06-18-2020, 06:02 PM
Thanks Jeff! Looks reasonably easy - if you know what you're doing :)
I'll look this over and give it a try.
thank you!
rich
Old 06-19-2020, 01:03 PM
Let me know if you have any follow up questions.
best,
Jeff
Jeff Komar
Old 06-22-2020, 08:01 AM
Just to refine this a bit. It is unnecessary to add the null Source Input to the monitor. I thought it was required, but alas it is not needed.
Make a new monitor, set TB mode, make an output path feeding DigiLink and set that as your Slate in PT and IO Setup. Done.
Jeff
Jeff Komar
Old 06-22-2020, 09:08 AM
Thank you again Jeff!
best,
rich
Old 06-22-2020, 11:02 AM
As a work-around, you could also route the TB mic(or any other mics) to AUX tracks and insert the sound Radix "Mute-o-matic" plugin(its free). You can set it so that TB mics are on when playback is stopped and muted as soon as transport rolls. My Nashville studio did that with 4 mics and it worked extremely well for communications between CR and anyone wearing headphones
Old 06-23-2020, 08:12 AM
Originally Posted by albee1952 View Post
... and insert the sound Radix "Mute-o-matic" plugin(its free)...
Thanks - Yes, know about and have mute-o-matic - it doesn't address the needs of this particular workflow.
best,
rich
Building a talkback switch mesaone General Discussion 4 02-14-2015 03:38 PM
External talkback mic/switch/cuelight switch Pete Gates Post - Surround - Video 3 03-16-2011 01:53 AM
Pro Control Talkback switch GrantFM ProControl, Control|24, Command|8 0 12-02-2009 11:44 AM
talkback switch TLarvenz ICON & C|24 1 06-06-2004 11:20 PM
Flaky talkback switch CraigLearmont ICON & C|24 1 12-16-2003 02:41 AM
