Old 04-04-2015, 09:22 AM
lvsranch lvsranch is offline
Default Midi edit window stuck to edit window
Hello, New to PT 11 and i've been trying to get the midi edit window to separate from the edit window as it used to do in PT 10. I have tried ctl = to know avail. I have also tried re-sizing and moving windows all about and no luck. Is there a setting I am not aware of here?
Old 04-04-2015, 10:07 AM
hjorte's Avatar
hjorte hjorte is offline
Default Re: Midi edit window stuck to edit window
Are you on Windows?
What language is your OS set up to use?
EDIT: wait a minute... you must use Start + = if you're on Windows. Not Ctrl.
Old 04-04-2015, 10:32 AM
Hi, Thanks for the reply. Yes I am on windows 7 sp1. I work with a dual monitor setup and I am now convinced there is a glitch of some sort going on as I can re arrange windows and all of a sudden the midi edit window will come up as a floating screen, but the minute I minimize it or cycle it with ctrl = it re-attaches. I am familiar with all of the window commands and have tried them all several times. On PT 10 I used to just edit my midi and then minimize the window and it would sit happily in the lower left corner until I needed it again. Now when I minimize it re-attaches to the edit screen bottom and will not let go. This is beginning to feel like a dreaded re-install coming on.
Old 04-04-2015, 10:43 AM
hjorte's Avatar
Can you make a video?
Old 04-04-2015, 10:49 AM
hjorte's Avatar
Originally Posted by lvsranch View Post
.. but the minute I minimize it or cycle it with ctrl = it re-attaches.
You don't recycle it with Ctrl+=. Read above. You recycle it with Start+=.
Old 04-04-2015, 10:53 AM
hjorte's Avatar
See this short video for troubleshooting inspiration. I just made it. Maybe it will tell you something:
https://www.youtube.com/watch?v=ULr4nlVG3NA
Old 04-04-2015, 12:35 PM
Hey thanks, I was doing ctl+= as opposed to start+=. Doh! I really appreciate the link to the video it got me back to good. Thanks again.
Old 04-04-2015, 12:42 PM
hjorte's Avatar
Good job
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Edit Window is stuck! Can't minimize or maximize. Please help! automatic8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-13-2021 03:23 AM
Sync Midi Window and Edit Window teafan Pro Tools M-Powered (Win) 1 08-28-2011 03:36 PM
MIDI edit page.... Edit Window Scrolling ... Page Norm Mix MIDI 1 07-06-2009 07:31 PM
Tracks Stuck as Hidden in Edit Window only?! reichman Pro Tools TDM Systems (Mac) 3 10-16-2008 09:19 AM
