Old 09-07-2016, 10:50 PM
jesele jesele is offline
Default Re: Not Remembering Window Positions
Thanks Art, I'll try that.
Jesper
Mac Pro 7,1 16-core, 96 GB, OS X.15.4, HDX 1, HD i/o 8x8x8 + HD i/o 16 digital + Metric Halo ULN 8 3D + RME Fireface 800
http://vicc.se/studio-alpha/
http://jesperelen.com
Old 09-08-2016, 03:22 AM
CHRIS AIKEN CHRIS AIKEN is offline
Thanks, I'll see if that works.
Old 09-08-2016, 04:18 AM
Originally Posted by rinky View Post
Move the window you want to the other monitor and press the green button on the top left to fully expand the window. Next time you launch PT, it should be where you left it.
At least that's what I did to solve this. Then I resized it afterwards.
Hope this'll work for you guys!
Art
Unfortunately that doesn't work for me. The both open on the main monitor when I close and reopen the session. Thanks for trying to help though!
Old 09-08-2016, 11:09 AM
Richard901 Richard901 is offline
Originally Posted by CHRIS AIKEN View Post
I have a hackintosh running El Capitan and Protools 12.5.2. I recently upgraded to El Capitan and Protools 12 at the same time.
I have dual monitors and I like to have the Mix and Edit windows each on their own screen.
Since upgrading I can't get my mix window and edit window to save in the right positions. When I open a session I put them where I want, when I close the session and reopen it they both are on top of each other on the right monitor.
Is this a bug or??
Thanks!
Here's a workaround that might help:
I use Divvy to arrange windows (size and position) on the screen. The manual states that it can be used with multiple monitors - I haven't tried this.
A free trial is available at:
http://mizage.com/divvy/
Pro Tools 2023.9
Ventura 13.6
Old 09-08-2016, 12:35 PM
Ticker Ticker is offline
I had a similar issue when I first got my 2nd monitor.
In my case, I wanted Mix window on the right monitor screen but saving and quitting always resulted in both Mix and Edit windows stacked on left screen.
A fix recommended by someone here on the DUC did the trick: dragged the Mix window farther over into the right screen than I would like - so there is exposed screen space to the left of the Mix window. Saved and reopened, the Mix window was finally on the right screen. After doing that, I could adjust position of Mix window however I liked and PT would still remember it each time.
Hope it helps!
Current system:
MacPro (Late 2013) 3.5 GHz 6 Core, 32 GB RAM
OSX 10.12.5
Pro Tools 12.8
Apogee Duet 2
Glyph Drives + Blackmagic dock with Samsung SSDs
Reason 10, Ivory II, BFD3, Finale
Plugins: Kush, Kontakt, Komplete Ultimate, Exponential Audio, Waves, Slate, Fab Filter, TDR, Pultec Bundle, Bomb Factory, UVI Workstation, Sonnox, Soundtoys, Massey, Valhalla, Aether, PhoenixVerb, etc...
also 17" MacBook Pro w Core i7, OSX 10.9.4
  #16
Old 09-08-2016, 04:22 PM
Thanks guys, I'll give those things a try tomorrow!
  #17
Old 09-08-2016, 11:59 PM
Yup, I'll be trying also.
Thanks.
Jesper
  #18
Old 09-09-2016, 02:31 AM
Extreme Mixing Extreme Mixing is offline
I fixed my problem by reversing the order of the plugs in the back of the computer. It seemed like one output wanted to be left and one wanted to default to right in the arrangement page. Once I changed everything works great.
Steve Shepherd
Extreme Mixing
  #19
Old 09-09-2016, 08:13 AM
Hope it helps!
We have a winner. That little tip seems to work here also. Thanks for the reply!!
  #20
Old 05-11-2020, 08:53 PM
Ben Jenssen's Avatar
Yes. Trick works for PT2020 remebering window positions on multiple screens. Just place the windows a bit "out of position" and the session reopens with same windows arrangment.
Once I save the session with windows full screen, all windows are back on main screen on re-open. Annoying and pitiful that this is not fixed.
7.4 not remembering my window positions crizdee Pro Tools TDM Systems (Mac) 8 11-26-2007 11:03 AM
MIX/ EDIT Window Positions anomoly Elton Hyland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-02-2007 02:38 PM
Screen/window positions - should this work? Trailerman Pro Tools TDM Systems (Win) 5 02-24-2006 10:05 AM
Remembering window positions for dual monitors. Swaphappy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-23-2002 11:54 AM
Saving window positions sburgess Digidesign Hardware & Software 0 04-25-2001 09:45 AM
