Old 07-04-2013, 04:31 PM
vorker vorker is offline
Default AAX Plug-Ins Not Recognized
Hello
I had a clean install of PT11; it's given me no problems thus far (unlike 10, which had so many bugs it was unusable)
I decided to install iZotope Ozone 5 bundle with the 64-bit AAX support. It installed successfully in the default location (C:\program files\common files\avid\audio\plug-ins) and folder shows up fine...
The issue is that when PT is booting, it scans the default Avid plug-ins and ignores the iZotope folder. The only other thing I tried was Battery 4 in AAX which is also ignored on boot up
Any suggestions or people who've had similar issues? Why isn't it recognizing 3rd party plugs?
Old 07-04-2013, 04:56 PM
Default Re: AAX Plug-Ins Not Recognized
Originally Posted by vorker View Post
Hello
First guess would be user error...
The missed the most useful info... you installed exactly what version of iZotope? Should be 5.04. Are you absolutely sure you did not accidentally run an old installer from a past (Pro Tools 10?) install?
NI Battery 4 does *not* have AAX-64 bit support so why are you expecting that to work?
How about some info about OS, computer etc. See the level of detail expected in the "Help us Help You - READ THIS Before Posting!" link above.
Darryl
Old 07-04-2013, 05:05 PM
It is iZotope 5.04 and it clearly specifies "AAX 64-Bit" in the installation
You're right about Battery though; I didn't realize that it was the old AAX support
That said, it's still not recognizing iZotope
Old 07-04-2013, 05:08 PM
Also, I'm running Windows 7 Home... the installer, as I said, is not an older version.
It is 5.04 and, again, offers support for "AAX (64-Bit)" only... In other words, there is no option to even install 32-Bit AAX options
Old 07-04-2013, 05:12 PM
You've got it right, 5.0.4 is Pro Tools 11 AAX-64/Pro Tools 11 (no AAX-32). I just wanted you to be sure you are really installing that, not say accidentally running an old installer after downloading the new one.
Darryl
Old 07-04-2013, 05:16 PM
Yep - I double checked too
From the iZotope site
"Enhancements and fixes:
Plug-in formats: Added 64-bit AAX support for Pro Tools 11
Please note: This update no longer supports 32-bit AAX. Customers accustomed to using 32-bit AAX in Pro Tools 10 can instead use the RTAS plug-in format without any degradation in audio quality. For your convenience, any session saved with the 32-bit AAX version of Ozone will automatically open with RTAS"
Also
What do you think the deal is? Any ideas come to mind?
Old 07-04-2013, 07:35 PM
The Weed's Avatar
The Weed The Weed is offline
Do a search. IIRC one of the folders is misnamed. Change the spelling and it should see the folder.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-04-2013, 09:25 PM
lukeg lukeg is offline
Make sure that the plugin is showing in the plugins folder - from memory in Win 7 it needs to be located in: programs/common files/avid/audio/plugins. I'm not at my computer at the moment so I will confirm for you later
Old 07-04-2013, 10:33 PM
I tried that actually... since all the folders in the Plug-Ins folder itself are named "Plugin.aaxplugin" and the DLLs and whatnot are within those, I renamed the folder "iZotope.aaxplugin" and it didn't work...
I'll try renaming the plugins individually and see what that does
Old 07-04-2013, 10:37 PM
It's definitely in that location; I even posted a screencap of the folder with all the other (working) plugins... It's just not recognizing it
Amplitube 2 Plug-Ins - Authorization not recognized Honeyy Pro Tools M-Powered (Win) 1 03-07-2013 02:01 PM
Musiclab plug-ins are not recognized kaet macOS 1 09-14-2011 05:44 AM
how to get third party plug in recognized? jonQpublic Virtual Instruments 4 03-31-2010 08:49 PM
Drivers/Plug ins not being recognized AudioArtCafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-06-2005 03:39 PM
Plug-In Presets not recognized Dog BBQ Pro Tools TDM Systems (Mac) 3 12-29-2001 12:48 AM
