Old 02-18-2014, 11:16 AM
mikeyman's Avatar
mikeyman mikeyman is offline
Default Avid Channel Strip
the channel strip is one Mother of a plugin.It has a lot going on.Anyone know of a good video on using it.There are four tabs at the top EQ,Compress ,Filter and Volume .What does the volume tab do?
Old 02-18-2014, 11:55 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Avid Channel Strip
The volume tab puts the input and output level controls into manual control.
with volume turned off, input and output is fixed! (no level trimming applied)
top of the input and output meters are the level controls
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-18-2014, 08:37 PM
mikeyman's Avatar
oh the top of the input and output meters is the controls
so when the tab is off. it's fixed and when its on you can adjust it..That helps..Thanks
Avid channel strip LCR Eruk AAX Plug-ins 5 02-11-2014 02:28 AM
Missing Avid Channel Strip after 10.3.5 install KerryLeigh Pro Tools 10 6 05-18-2013 11:08 AM
Avid Channel Strip Melodic Wave Windows 3 03-28-2013 11:19 AM
Can you track with Avid Channel Strip plug in? crazyhorserocks Pro Tools HDX & HD Native Systems (Mac) 6 03-11-2012 02:20 PM
Can the Avid Channel strip do ducking? Ling Pro Tools 10 1 10-22-2011 11:08 AM
