Move my PT soft from G4 to G5 any tips ??
Hi;
I'm gonna transfer my PT HD2 from a G4 to a G5 in a few days. Any tips you can give for the softwae side. Someone mentioned swapping the OS disk, but since my new baby has a Raptor 10000 rpm, I need to transfer it to this one. |
Re: Move my PT soft from G4 to G5 any tips ??
You could use the Apple Migration Assistant but if you have the time and patience I think it is better to just start from scratch and install everything that you need. I think people have had a lot of luck using the Migration Assistant so you could always give that a try and if it didn't work you could just format the drive and start again.
- Jason |
Life is good !! Marcello Azevedo |
What I would do is boot off of your OS install dsic on the G4, go to disk utility and make a disk image of your system drive to another drive (portable firewire drive would be easiest) Next boot your G5 off the install disc and then go to disk utility and restore that system drive image on your G5 system drive. The only thing you might have to do next is an archive and install of the actual OS to get the proper G5 drivers and whatnot. I've done this many times and it is perfect.
However, I enjoy starting from scratch every now and then to get rid of all the crap that seems to collect. |
thanks for the tips , But I guess the mentioned disk image things won't work.
I'm upgrading from OS10.3.9 to Tiger at the same time . |
It'll work, just use the tiger installer for the archive and install after restoring the image on the G5. And don't forget to repair permissions as the last step.
I would say install from scratch, also. I just did this btw.
One very important note, the drives you have in your G4 are not compatible with the G5; the connectors are different. Here_is_a_picture_of_the_connectors |
Tips for moving custom user sets/soft keys to a new computer? | mrsquid | Artist Series | 1 | 04-04-2013 02:37 PM |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
Can I move regions and have the underlying playlists move also? | smpkeys | Pro Tools TDM Systems (Mac) | 4 | 02-18-2010 07:30 AM |
Time to move the Digi001, tips, what to do? | nuke | Tips & Tricks | 2 | 02-24-2007 03:19 AM |
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? | rtcstudio | Pro Tools TDM Systems (Mac) | 3 | 11-16-2002 07:57 PM |
