Old 09-05-2020, 02:07 AM
idris idris is offline
Default Edit window fade shape editing
Despite using PT since V3, some features I've never used ...
I use the Smart Tool all the time, and create fades using that or keyboard short cuts D / F / G almost exclusively.
So when I place the cursor over a fade in the edit window, and the fade curve turns yellow, I expect to be able to change the shape directly. Except I can't. Which is borne out by this old thread ... PT12.6 Bug With New Edit Window Fade Shaping Feature
So what is the work flow for creating a fade that can be editted directly with the smart tool in the edit window?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 09-05-2020, 11:53 AM
rhumphries rhumphries is offline
Default Re: Edit window fade shape editing
There is a check box in preferences that either enables it always or with the requirement of adding the ctrl key.
Once enabled just grab on the fade from the middle of the waveform (i.e. not the top or bottom) and drag left or right.
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 09-05-2020, 12:53 PM
Do you mean "Smart Tool Fade Adjustment"? Even with it set to "Always On", I still can't adjust the fade shape with the Smart Tool. Changing it to "Requires Command Key" means the fade shape doesn't highlighted in yellow, but neither setting allows me to adjust the shape.
Old 09-07-2020, 07:45 AM
nedd nedd is offline
Check your Fade "Shape"
if the shape is either Standard or S-Curve you can change it with smart tool.
if the shape is one of the presets than it won't work.
Old 09-07-2020, 07:51 AM
...also change the "Default Fade Settings" in the prefs. Use one of the two above mentioned.
HTML code is On
PT 12 editing issues - cursor won't move, edit window jumps. Tad Wadhams Pro Tools 12 6 02-26-2021 08:00 PM
PT12.6 Bug With New Edit Window Fade Shaping Feature pdubber Pro Tools 12 3 10-06-2016 06:32 AM
Editing Portamento in PT edit window? kirkbross MIDI 1 02-11-2009 07:05 PM
Demonic Fade Shape Bug! Stuart P. Post - Surround - Video 32 08-03-2004 07:59 AM
fAde shaPe and tRim buG in PT6 jimlongo Pro Tools TDM Systems (Mac) 3 06-17-2003 11:28 AM
