Old 12-06-2012, 03:12 AM
Weird Audio Weird Audio is offline
Default AUTOMATION TO DENSE then stops..... I have no automation
AUTOMATION TO DENSE then stops..... I have no automation except muted and unmated clips if that counts for much. I even have all automation turned off on every track except inactive tracks . This is seriously putting a humper on things . On a side note my SSD Trigger samples are not showing up in the plug like they should and often have to reinsert them .
Old 12-07-2012, 05:50 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: AUTOMATION TO DENSE then stops..... I have no automation
Can you copy the session to a different drive to test if its the SSD drive.
Seen a few problems with SSD drives and needing firmware updates etc.
Chris
Producer, Engineer,
www.ukmastering.com
Automation is too dense (-9155) HDXSound Pro Tools HDX & HD Native Systems (Mac) 9 09-27-2013 01:02 AM
Automation stops working tsanders 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2007 02:53 PM
Automation too dense ? deardaddy Pro Tools TDM Systems (Mac) 4 08-26-2006 11:23 AM
automation is too dense? c-post Pro Tools TDM Systems (Mac) 6 07-03-2006 07:07 PM
Automation too dense during BTD roykamen Pro Tools TDM Systems (Mac) 6 12-12-2000 10:44 PM
