Firewire 800 + 400 can't be used simultaneously? Why?
Quote from http://www.digidesign.com/index.cfm?...4&itemid=23126
"- FireWire 400 and FireWire 800 drives should not be combined" I have 2 old external Firewire 400 enclosures (PATA). One of the drives is failing. If I use the opportunity to start upgrading to Firewire 800, do I have to update both enclosures to 800 (recording and virtual instrument drive)? Apparently digidesign doesn't support use of 800 and 400 at the same time. Is this still true? Does that include 1 drive on a 400 port and the other on the 800 port? Any personal experiences? |
Re: Firewire 800 + 400 can't be used simultaneously? Why?
From what I have read on the DUC, I would stick with FW400 all around.
Even for 2 daisy-chained drives? |
Just reading my new Glyph manual. While it does not claim that you may not run FW400 & 800 together, as PT literature suggests, it does say that the bus will run at the slowest speed of any the attached FW device. So why drag your 800 down to 400?
BTW, I am rummaging around here trying to see if eSATA will be my best connection to external HD, it is much faster than FW800, according to Glyph.
Woody Woodruff The Gem Theater, St Louis MI Digi 003 Rack, MOTU 828 MkIII Mac Lepoard 10.5 Duo Core2, 4G RAM Glyph GT050Quad500 PT v 7.4.2 Home DAW MBox 2 MacBook 13" 2.1GHz, 4G RAM Glyph GT050Quad500 PT v 7.4.2 (v 8 when available) |
I have both connected to my system. Have had no trouble. Even had both types at once on 400 holds my samples for soft synths. 800 had sessions.. no problem.
www.garyvandy.com |
Choice:
1. Firewire 400 drive. 2. Firewire drive with 400, 800, esata, USB (e.g. Lacie d2 Quadra) - connected with Firewire 400 cable. Assuming both drives have Oxford chipsets, are they both as compatible with Pro Tools (CPU error messages, etc.)? Do the extra interfaces in choice 2 lead to problems, even though they are not connected to the computer? Thanks for your help. Richard |
Gents: some of you are NOT reading the fine print here...
YES, mixing FW800 and FW400 on the same bus will WORK, HOWEVER, you have now crippled your FW800 device to FW400 speed. If you are happy, then move on....but why invest in FW800 technology not to use it?
--Jeremy |
Has anybody tried eSATA with PT8 ?
Re: eSATA with PT8 works fine
In February, I did have a terrible problem with a cheap Sonnet eSATA card, though. On MacGurus' recommendation, I switched to Lycom and everything worked. Best, Nathaniel Reichman www.nathanielreichman.com MacPro 2.8Ghz 8-core, 6GB RAM, 10.5.6, Pro Tools LE 8.0.0cs2 with Complete Production Toolkit, Digi 002R, Control|24, Blackmagic Intensity Pro, eSATA hotswap tower, Baby HUI, Soundminer 4, Waves Platinum 6, Audio Ease All-In, Melodyne, SoundToys, Izotope RX, GRM Tools, PSP, Retrospect... |
1 rig, 2 mics simultaneously | christunger | Eleven Rack | 9 | 05-29-2013 05:07 AM |
Using 003 and 11R inputs simultaneously? | 00011011 | Eleven Rack | 2 | 10-18-2010 08:48 PM |
Can I have 16 analog I/O simultaneously on a 192.. | Renie | Pro Tools TDM Systems (Mac) | 5 | 04-29-2004 02:05 AM |
Using 888/24 and 888/16 Simultaneously | Rail Jon Rogut | Pro Tools TDM Systems (Mac) | 1 | 03-27-2003 12:53 AM |
Firewire Video and Audio Simultaneously | Carl Sealove | Pro Tools TDM Systems (Mac) | 7 | 11-03-2002 09:33 AM |
